, B' N- o- M3 c2 r& s" [ 基于风、浪、流参数的畸形波发生概率预测方法研究 6 c- F& I+ ~7 K& @! k/ |' i
全文请用PC端下载 地址:
4 x D2 s8 t- c0 i8 P! @$ X http://www.hyyb.org.cn/Magazine/Show.aspx?ID=3688
" Z/ Y3 Z+ V7 \3 i/ | 读书小笔记 * q2 J& V+ A% o. q2 _; H
作者:王译启1任林1杨劲松1 2李晓辉1韩心海1 2
! z5 h. b1 F7 l. F 单位:
! B/ w( Z9 \! w" z0 ?6 y 1. 自然资源部第二海洋研究所 卫星海洋环境动力学国家重点实验室, 浙江 杭州 310012;2. 上海交通大学 海洋学院, 上海 200240 " w$ |( w( e$ `; N# F7 M
分类号:P731.33
! {+ J* j! N# ?0 u% x7 v* D6 J 出版年·卷·期(页码):2025·42·第六期(24-33) 7 `7 m" ~6 _1 M3 |. p% ^. r$ ^1 A
摘要:基于58个波浪浮标的观测数据及风场、流场的再分析资料,利用滑动窗口法分析了多个海况参数与畸形波发生概率(RWO)的关系。结果表明:有效波高与RWO之间存在显著的负相关关系;随着风速增加,RWO先减小后增大,随着流速增加,RWO先增大后减小,但均在特定阈值处转折;不同风浪夹角下RWO变化较小,浪流夹角为锐角时RWO略大;随着相对水深增加,RWO存在一定下降趋势。从海况参数与RWO的相关性出发,选择有效波高作为主要建模参数。在此基础上,由于不同风速对畸形波的调制作用不同,探讨了不同风速下畸形波发生概率随有效波高的变化情况,并确定了最佳风速阈值。根据不同风速条件下有效波高与RWO的关系,将低风速与中等风速小波高(有效波高≤5 m)数据合并建模,中等风速大波高(有效波高>5 m)单独建模,并在测试集上进行验证。结果表明:在低风速及中等风速小波高条件下,真实RWO与模型预测RWO的决定系数和均方根误差分别为0.97和0.001 9;中等风速大波高条件下分别为0.81和0.003 5。
! n7 L) d% c/ y" u+ D 关键词:畸形波 有效波高 波浪浮标 风速 4 N% L9 q% Q- q, G6 {) G5 F7 g
Abstract:Based on observational data of 58 wave buoys and reanalysis data of wind and ocean current, the relationship between multiple sea state parameters and rogue wave occurrence(RWO) is analyzed based on sliding window method. The results show that there is a significant negative correlation between effective wave height and the RWO. The RWO first decreases and then increases along with the increase of wind speed, while first increases and then decreases along with the increase of current speed. The RWO changes small under different wind-wave angles, but is relatively large under acute current-wave angle. The RWO has a downward trend when the relative water depth increases. Significant wave height is selected as the main parameter to build model considering the correlation between sea state parameters and the RWO. Further, the change of the RWO with significant wave height under different wind speeds is discussed and the optimal wind speed threshold is determined. As a result, the data of low-moderate wind speed with small wave height(significant wave height ≤5 m) are categorized to build a model, and the data of medium wind speed with large wave height(significant wave height >5 m) are separately categorized to build a model. Validation shows that the coefficient of determination and root mean square error between the real RWO and the predicted RWO are 0.97 and 0.001 9 under low-moderate wind speed with small wave height, and the values are 0.81 and 0.0035 under medium wind speed with large wave height.
! w: v+ r |- o# o. F Key words:rogue wave; significant wave height; wave buoy; wind speed K" l, C- U: r; T
读者也可以通过公众号菜单栏
$ d/ n+ {$ E2 v6 U* n “相关知识”板块进入
5 [3 L# Y+ e& g# h* I 《当期目录》和《过刊浏览》 + ]( j3 E. i* w- A$ N
查阅详细期刊内容 / d. P$ T6 \8 p
未来两天海洋环境预报
( d/ ?4 t2 Q. {4 _ 预计明天, 8 h7 P2 t4 @( Q7 v1 U0 c; }
渤海有0.7到1.2米的轻浪; ( ~' _) M# p( J) a7 z
黄海北部有1到1.6米的轻浪到中浪; ; O/ ~$ i3 ?/ `) }! I+ L2 P- u+ p( } `
黄海南部有1.5到2.1米的中浪区; 9 ~- t. l! a' ]; P' G
东海北部有1.8到3.2米的中浪到大浪区; ) t. Y4 i1 W1 a( H
东海南部、钓鱼岛附近海域有2.1到3.1米的中浪到大浪区; : z$ t( U8 p0 o ~4 D' I
台湾海峡有3.1到3.6米的大浪区;
, P9 w" r8 {0 ]; S F. m. b' z h( } 台湾以东洋面有2.9到3.7米的大浪区; - {+ t: G3 N& ?' c
巴士海峡、南海北部有3.4到4.1米的大浪到巨浪区;
7 F! o \/ n. S 南海中部有3到3.5米的大浪区; 7 D6 ~. F$ z/ b$ g q' m
南海南部有2.3到2.9米的中浪到大浪区; ( V4 Z' [/ ?9 [+ G) Z
北部湾有1.4到1.8米的中浪。
$ Q j+ l. K9 h) ~& ~ @3 G/ _, b6 \ 预计后天,
0 J- ?1 H; s5 i0 Y 东海北部的大浪区减弱消失;
5 J" n Q* d+ F$ N8 x6 g 东海南部、钓鱼岛附近海域的大浪区维持,浪高1.8到2.8米;
- n% n! v/ X; O% V 台湾海峡的大浪区维持,浪高2.4到3.6米; $ b: i; d# d; Y. p* v
台湾以东洋面的大浪区维持,浪高2.6到3.7米; 0 s* w" C9 A m9 S
巴士海峡、南海北部的大浪区维持,浪高3.6到4.4米; $ i, ~' O% h- P% b; m
南海中部的大浪区维持,浪高3.1到3.7米; 7 Q% b/ q# _1 O7 n
南海南部的大浪区维持,浪高2.5到3米。
- m3 ?8 L, h7 y+ s$ T/ F* c 2月1日~2月5日西北太平洋海浪数值预报 , @6 w. C- N$ B& p
35个美丽海岛环境预报
' R4 a0 I& g) F& f0 a7 ^# R3 ~6 ~ 预计明天, * _' ]) O2 l# W( p1 I# N
永兴岛、黄岩岛、永暑礁附近海域有2.5~3.3米的大浪,平潭岛、湄洲岛、东山岛、钓鱼岛、分界洲岛、蜈支洲岛附近海域有2.2~2.3米的中浪,以上海岛都不适宜乘船出行;
) z& F( b! K. i: K8 G 南澳岛、川山群岛附近海域有1.9~2米的中浪,刘公岛、东极岛、洞头岛、南麂岛、嵛山岛、万山群岛、海陵岛、南三岛、东海岛附近海域有1.3~1.5米的中浪,这些海岛较适宜乘船出行和海岛游玩;
, F( y% F1 ?6 p, W+ _; k- O 我国其他主要美丽海岛附近海域都是轻浪,海况不错,非常适宜乘船出行和海岛游玩。
) P! N N2 E# G% i6 f 35个美丽海岛是指以下海岛:
+ D7 t. [& M# c+ c 觉华岛、长山群岛、菩提岛、长岛、刘公岛、灵山岛、秦山岛、连岛、崇明岛、嵊泗列岛、岱山岛、东极岛、普陀山、大陈岛、玉环岛、洞头岛、南麂岛、嵛山岛、三都岛、平潭岛、湄洲岛、东山岛、钓鱼岛、南澳岛、万山群岛、川山群岛、海陵岛、南三岛、东海岛、涠洲岛、分界洲岛、蜈支洲岛、永兴岛、黄岩岛、永暑礁。  / I- a. T K8 R' U1 {
更多滨海旅游海况预报 尽在中国海洋预报
! K. e/ e7 f( }9 T5 i& r PC端可登录中国海洋预报网http://www.oceanguide.org.cn 7 x0 j* {3 M( Q4 l+ E
进入“中国海洋预报”微信小程序 " `& O1 B# w4 h' z s# Z7 u& A
进入“全球海啸预警”微信小程序 # Z2 D( ~) }( w) O
3 t# H& E6 K4 `6 P" n, E# c
+ [0 j' W' A' P9 W( ^* ]6 c9 P
0 u- N7 D. h* u, D) ~
