【浮游生物类仪器】德国HYDRO-BIOS公司 浮游动物计数框
德国HYDRO-BIOS公司——浮游动物计数框/ M0 R3 F& `4 W4 Y. |0 ^0 U
Counting Chamber for zooplankton
- T7 u$ _9 p$ ]$ b( w
" w7 z$ n' ?7 i( ]/ z9 e
  s. j% z5 [* C  ~. P2 i6 V# u
9 U! W  {. m' G. n: m! E8 ]! E: n
4 I3 L4 J( E; f0 H1 f
浮游动物计数框用于在体式显微镜底下对浮游动物进行观察计数。浮游动物计数框由树脂材料制成,底面抛光,具有较好的透明度,可将其放置到常规显微镜上对浮游动物进行观察。) n6 ]0 Z$ P, `4 l
( a+ K! H, a7 r+ i6 @( {
' _$ \! ^9 i6 K2 _# S8 N6 n
; L/ S) B% t* `- \
: u4 ?# l2 a4 |4 t7 ]* K
浮游动物计数框订购指南:8 l- W- o# W* s2 P
浮游动物计数框由树脂材料制成,底面抛光,具有很好的透明度
3 x+ S1 {8 S/ O! Z+ C
" s' x4 j1 ?: Y8 ~
: e  [; D$ E3 x4 `/ _) K# _/ @5 Y
        435 010     浮游动物计数框尺寸40×70mm,容纳样品量约9ml# i  t( [8 P8 n
2 u" h5 g% {& i/ j
0 d; x4 ~) M! S0 t
        435 011      浮游动物计数框尺寸80×100mm,容纳样品量约22ml5 c$ m" n' `( f* J2 P
        435 011A   浮游动物计数框尺寸80×100mm,容纳样品量约6×5.4ml
( u/ v0 s  A$ q" G        435 011B   浮游动物计数框尺寸80×100mm,容纳样品量约12×2.4ml
( F" o: ^( d! \0 ?+ D' s        435 011C   浮游动物计数框尺寸80×100mm,容纳样品量约30×0.8ml0 y) l/ Z6 a( J" ^1 Z& m% g
8 D9 R- e' I/ Y" r7 f1 C
: [8 n0 ~- H; G# _% F
        435 012    浮游动物计数框尺寸80×140mm,容纳样品量约70ml
1 R% E- V' T1 P2 `2 u+ c, D/ C7 e- C* u4 h
! B6 h# z4 W) B3 R6 }代表文献:
% A2 H  F* |# z% _# F* i1.Manfred Rolke and Jürgen Lenz,1984.Size structure analysis of zooplankton
! w7 `7 i$ w8 U3 C* U. T' y
samples by means of an automated image analyzing system.Journal of Plankton Research.6(4): 637-645.
( z5 A# d$ t1 I% `8 i+ N2.Austin B.M. Egborge and Prekeyi Tawari,1987.The rotifers of Warri River, Nigeria.Journal of Plankton Research.9(1):1-13.
+ F0 V# p5 o* `% \3.J.W. Rijstenbil,1987.Phytoplankton composition of stagnant and tidal ecosystems in relation to salinity, nutrients, light and turbulence.Netherlands Journal of Sea Research.21(2):113–123.: [7 {% ?& _6 z. S
4.S. Wagener, C. F. Bardele, N. Pfennig,1990.Functional integration of Methanobacterium formicicum into the anaerobic ciliate Trimyema compressum.Archives of Microbiology.153(5):496-501.
% ~% q  c% e: \( R& F5.S. Holler, N. Pfennig,1991.Fermentation products of the anaerobic ciliate Trimyema compressum in monoxenic cultures.Archives of Microbiology.156(4):327-334 .
0 P. f! R+ ~0 h+ d" E/ ?9 C6.J. W. Rijstenbil, C. Bakker, R. H. Jackson, A. G. A. Merks, P. R. M. de Visscher,1993.Spatial and temporal variation in community composition and photosynthetic characteristics of phytoplankton in the upper Westerschelde estuary (Belgium, SW Netherlands).Hydrobiologia.269-270(1):263-273.
9 q' F3 Y- t2 z% }# b0 p7.Bettina Meyer-Harms, Falk Pollehne,1998.ALLOXANTHIN IN DINOPHYSIS NORVEGICA (DINOPHYSIALES, DINOPHYCEAE) FROM THE BALTIC SEA.Journal of Phycology.34(2):280–285.
4 m6 V, m4 w) X$ Z8.Catalina Castell Perez, Suzanne Roy, Maurice Levasseur, Donald M. Anderson,1998.CONTROL OF GERMINATION OF ALEXANDRIUM TAMARENSE (DINOPHYCEAE) CYSTS FROM THE LOWER ST. LAWRENCE ESTUARY (CANADA).Journal of Phycology.34(2):242–249.
  ?" q) j) `1 O9 H' U" [4 F" a9.Teresa Cruz and Jorge Araújo,1999.Reproductive Patterns of Pollicipes pollicipes (Cirripedia: Scalpellomorpha) on the Southwestern Coast of Portugal.Journal of Crustacean Biology.19(2):260-267.: i6 e3 L6 l( ]! c9 i
10.Michael Hust, Wolfgang E Krumbein, Erhard Rhiel,1999.An immunochemical in situ approach to detect adaptation processes in the photosynthetic apparatus of diatoms of the Wadden Sea sediment surface layers.Journal of Microbiological Methods.38(1–2):69–80.5 R$ r: c- H% M
11.Christine Dupuy, Solange Le Gall, Hans J. Hartmann, Martine Bréret,1999.Retention of ciliates and flagellates by the oyster Crassostrea gigas in French Atlantic coastal ponds: protists as a trophic link between bacterioplankton and benthic suspension-feeders.Marine Ecology Progress Series.177:165-175.
0 l! D8 X' t! D. S1 [9 w' [12.A. Tewari, H.V. Joshi, R.H. Trivedi, V.G. Sravankumar, C. Raghunathan, Y. Khambhaty, O.S. Kotiwar, S.K. Mandal,2001.The Effect of Ship Scrapping Industry and its Associated Wastes on the Biomass Production and Biodiversity of Biota in in situ Condition at Alang.Marine Pollution Bulletin.42(6):461–468.& Q& U5 C* m+ v
13.Hera Karayanni, Urania Christaki, France Van Wambeke, Andrew P. Dalby,2004.Evaluation of double formalin—Lugol's fixation in assessing number and biomass of ciliates: an example of estimations at mesoscale in NE Atlantic.Journal of Microbiological Methods.56(3):349–358.  w0 W& q4 F, P$ L$ f/ w2 d
14.EI Ohimain, TOT Imoobe & MO Benka-Coker,2005.The impact of dredging on macrobenthic invertebrates in a tributary of the Warri River, Niger delta.African Journal of Aquatic Science.30(1):49-53.
2 g, V  C% N: H2 P; E  i# I, E& b. V  s15.Laurent Seuront, Dorothée Vincent, James G. Mitchell,2006.Biologically induced modification of seawater viscosity in the Eastern English Channel during a Phaeocystis globosa spring bloom.Journal of Marine Systems.61(3–4):118–133.  T7 _5 V; E' ]8 X) V$ n
16.Wim A.M. Hijnen, Yolanda J. Dullemont, Jack F. Schijven, Anke J. Hanzens-Brouwer, Martine Rosielle, Gertjan Medema,2007.Removal and fate of Cryptosporidium parvum, Clostridium perfringens and small-sized centric diatoms (Stephanodiscus hantzschii) in slow sand filters.Water Research.41(10):2151–2162.
, D- ^+ \* w* c1 D: K$ V$ V& j17.Géraldine Sarthou, Dorothée Vincent, Urania Christaki, Ingrid Obernosterer, Klaas R. Timmermans, Corina P.D. Brussaard,2008.The fate of biogenic iron during a phytoplankton bloom induced by natural fertilisation: Impact of copepod grazing.Deep Sea Research Part II: Topical Studies in Oceanography.55(5–7):734–751.0 n4 N: g/ K# `
18.Damir Viličić, Tamara Djakovac, Zrinka Burić, Sunčica Bosak,2009.Composition and annual cycle of phytoplankton assemblages in the northeastern Adriatic Sea.Botanica Marina.52(4):291–305.( J* B. e. x! h! K
19.Fedekar F. Madkour, Mohsen M. El-Sherbiny and Maher A. Aamer,2010.Phytoplankton population along certain Egyptian coastal regions of the Red Sea.Egypt J. Aquat. Biol. & Fish..14(2):95-109., ?9 n9 w7 `& |" v. z4 I5 {) x- o
20.Mianrun Chena, Bingzhang Chena, Paul Harrisonb, Hongbin Liu,2011.Dynamics of mesozooplankton assemblages in subtropical coastal waters of Hong Kong: A comparative study between a eutrophic estuarine and a mesotrophic coastal site.Continental Shelf Research.31(10):1075–1086.8 m) D0 V* f+ p2 k$ {
21.Germán A. Kopprio, Gerhard Kattner, Martin Graeve, R. Hugo Freije, Rubén J. Lara,2012.Exceptional lipid storage mode of the copepod Boeckella poopoensis in a pampean salt lake, Argentina.Aquatic Biology.15:275-281.0 s# M6 r* a5 R
22.Dongyan Liu, Yajun Shi, Baoping Di, Qianli Sun, Yujue Wang, Zhijun Dong, Hongbing Shao,2012.The impact of different pollution sources on modern dinoflagellate cysts in Sishili Bay, Yellow Sea, China.Marine Micropaleontology.84–85:1–13.
% o4 U4 [& `) [23.Daniel Remias, Andreas Holzinger, Siegfried Aigner, Cornelius Lütz,2012.Ecophysiology and ultrastructure of Ancylonema nordenskiöldii (Zygnematales, Streptophyta), causing brown ice on glaciers in Svalbard (high arctic).Polar Biology.35(6):899-908.: _& ?0 X4 e* Y, w3 U
24.F.S. Tahami, A.G. Mazlan, H. Negarestan, Sh. Najafpour, W.W.M. Lotfi and G.D. Najafpour,2012.Phytoplankton Combination in the Southern Part of Caspian Sea.World Applied Sciences Journal.16(1): 99-105., X8 j  e+ j/ m3 Z( P
25.Amir Abbas Bazyar Lakeh, Werner Kloas Rainer Jung, Ra’anan Ariav, Klaus Knopf,2013.Low frequency ultrasound and UV-C for elimination of pathogens in recirculating aquaculture systems.Ultrasonics Sonochemistry.20(5):1211–1216.
6 R: q9 b5 T0 X& q6 D- k$ @& m  H7 I2 @/ q
* u. {" M1 o0 [3 L更多关键字: 浮游动物计数框,浮游生物计数框,浮游生物观察组件
" G/ \/ A2 T4 [8 U
: |2 ?  J! _* M2 x6 g7 F
5 e, H* v" D3 R
0 Y4 }( i0 B3 p$ g2 }, i- t* Q6 j<strong>
