[Generic Mapping Tools (GMT)] Pygmt利用在线数据绘制地形图
GMT和Pygmt提供了一个远程数据功能,可以使用函数datasets远程下载多种在线数据,并进行处理和绘图。这里以pygmt为例绘制海底地壳年龄、陆地地形。
地壳数据[1]包含了不同的分辨率,对应不同文件大小,最粗为1d,全球数据仅125K,最大分辨率1m,全球数据188M。绘图
% M0 ~% c' w- a8 A& C
[C] 纯文本查看 复制代码
import pygmt
grid_globe = pygmt.datasets.load_earth_age(resolution='06m', region="-180/180/-90/90", registration=None)
fig = pygmt.Figure()
fig.grdimage(grid=grid_globe, projection="R15c", region="0/360/-89/89", frame=True,cmap="crustal_age.cpt")
fig.colorbar(frame=["af", "x+lage", "y+lMyr"],cmap="crustal_age.cpt")
fig.show()
) f3 p$ b7 O1 t( d. x& x: l, f
9 y% J* I# D+ o9 P: x2 M
2 ^- z5 ]0 i% j7 r+ R( }0 a1 ], b
上面的调色板crustal_age可以在.gmt/cache/下找到,而远程数据也下载到了./gmt/server/下面。
. L% T+ f7 T/ N5 p
地形数据
地形数据[2]包含多种不同分辨率,对应不同的文件大小,最粗为1d,文件大小128k,最高分辨率为1s,文件大小达41G:
SRTM绘图
[C] 纯文本查看 复制代码
# 雅鲁藏布江大峡谷[/b]grid = pygmt.datasets.load_earth_relief(
    "03s",
    region=[94, 95.5, 29, 30],
    registration="gridline",
    use_srtm=True,
# calculate the reflection of a light source projecting from west to east
# (azimuth of 270 degrees) and at a latitude of 30 degrees from the horizon
dgrid = pygmt.grdgradient(grid=grid, radiance=[270, 30])
fig.grdimage(grid=grid, projection="M15c", region=[94, 95.5, 29, 30], frame=['WSrt+t"Original Data Elevation Model"',"xa", "ya"],cmap="dem1")
fig.colorbar(position="JML+o1.8c/0c+w10c/0.9c",frame=["af", "y+lmeter"])
fig.coast(rivers="a/1p",borders="2/5,red")
# Shift plot origin of the second map by 12.5 cm in x direction
fig.shift_origin(xshift="20c")
pygmt.makecpt(cmap="gray", series=[-1.5, 0.3, 0.01])
fig.grdimage(
    grid=dgrid,
    projection="M15c",
    frame=['lSEt+t"Hillshade Map"', "xa0.1", "ya0.1"],
    cmap=True,
fig.grdimage(
    grid=grid,
    shading=dgrid,
    projection="M15c",
    cmap="dem1",
fig.show(width="20c")
fig.savefig("srtm.png")
3 r0 y* d: Q4 j6 m9 o$ f% c6 L! R' ^1 O/ O8 u: C  [7 C7 _, x  K8 B2 C. R
2 N" |, f2 }6 |1 W9 b& |
  F# g5 J# {" ?# L9 ^3D地形图
; n: U2 j( Z4 B3 k: A- Q
[C] 纯文本查看 复制代码
fig.grdview(
    grid=grid,
    region=[94.7, 95.2, 29.5, 30],
    perspective=[250, 60],
    frame=["xa", "ya", "WSNE"],
    projection="M15c",
    zsize="15c",
    surftype="s",
    cmap="dem1",
    # Set the plane elevation to 1,000 meters and make the fill "gray"
    plane="000+ggray",
fig.show()
2 ~, Y" F. O  F2 ~
3 j3 C. v4 I7 A; N( D, j
同样,我们还可以使用pygmt.grdview绘制三维地形图。下面是我曾经到过山脚下,但是在云中的南迦巴瓦峰。
  v, C% W$ D, |3 a$ E8 Q2 k/ ]
1 M; U2 c' ^+ u7 q* j" _1 R1 l8 R3 x4 J# r
, ~7 Z+ E4 M' x9 B6 C附:遥感影像和地形的结合
在github存在一个30Day*****的系列代码库,其中包含绘图领域的30DayMapChallenge2021,恰好已经使用GMT完成了这项工作,作者是Pygmt的核心开发者Weiji。
这里有两个遥感影像和地形结合的例子(17和18),可以作为很好的学习材料.
# H' ?9 |" P% u' \ 890462c83b5b71c55982edf82ce3db71.png ) `/ i7 v7 h. K" b. ^* j( T+ s( {: I9 J' |, s
" J' S- T. C' s' {' }, ?, u1 W: KReferences[1] 地壳数据: https://www.generic-mapping-tools.org/remote-datasets/earth-age.html
5 A9 [9 H/ [6 b* H0 m: x7 b[2] 地形数据: https://www.generic-mapping-tools.org/remote-datasets/earth-relief.html. z* T  \* P# U4 o
, u/ I# Q% }/ D' E1 `* ]来源:海洋遥感数据共享
. h/ S  s  i/ q: v
7 G4 P4 p& U+ N) s) q$ {- ?
