德国HYDRO-BIOS公司——Kolkwitz浮游植物计数框 ! ?% v# r& `4 l+ D$ Z+ C# i
0 ?, | U% v9 F7 r
: m _8 N" I- K$ y. ?. g" K9 I
7 t h' f! [3 B% J: }4 p/ J2 N
0 V) d% M* m/ @$ J* z8 R. l1 ] m" u Kolkwitz浮游植物计数框用于在倒置显微镜下对浮游植物进行观察计数。( ?; d Q5 Y9 L& X' w' z
# K7 h: @) ^# p+ ^3 fKolkwitz浮游植物计数框订购指南:
- w7 r# r+ m0 A: v435 015 Kolkwitz浮游植物计数框 ) j$ G& k% }) y" |! N
包含带计数网格的盖片
7 Y& _5 x( E1 G6 x! p 网格大小 1×1mm5 q8 c' t2 b9 J. V; x
尺寸 33×33mm
4 I3 [7 b: U) p1 n 盖玻片厚度 1.3mm4 D" K- f- \) J3 _' j
计数孔直径22mm/ k2 c* y2 V4 h4 |: b# G- D2 \
样品容量0.5ml(经过精确校准的)! l p0 Y! n0 q
* u8 c. `: d6 p3 }/ ]
435 016 Kolkwitz浮游植物计数框9 B3 f: F4 C9 c% y) A3 [& Q% a% L/ ?; H
包含带计数网格的盖片1 n" v0 }4 R# I1 ?
网格大小 1×1mm
$ [- L p( X. @1 U# T; H1 }( r 尺寸 33×33mm* Z/ ]+ t$ E1 t+ h
盖玻片厚度 2.6mm
( G* f, \7 B5 a7 @ 计数孔直径22mm
1 z4 X- W1 K7 r* ^/ j4 X 样品容量1.0ml(经过精确校准的)( L4 ~& H/ z$ Q1 Y0 H" [" x+ i
" L5 Z; N! V$ R4 W/ f5 y) q代表文献:% x4 ^2 P2 t/ Y1 Q, n- X0 q
1.Manfred Rolke and Jürgen Lenz,1984.Size structure analysis of zooplankton samples by means of an automated image analyzing system.Journal of Plankton Research.6(4): 637-645.& L) Y, \9 c% t
2.Austin B.M. Egborge and Prekeyi Tawari,1987.The rotifers of Warri River, Nigeria.Journal of Plankton Research.9(1):1-13.5 V4 o1 `8 }& d
3.J.W. Rijstenbil,1987.Phytoplankton composition of stagnant and tidal ecosystems in relation to salinity, nutrients, light and turbulence.Netherlands Journal of Sea Research.21(2):113–123.; c8 Y7 z9 H+ p6 l' ?6 s- D4 p
4.S. Wagener, C. F. Bardele, N. Pfennig,1990.Functional integration of Methanobacterium formicicum into the anaerobic ciliate Trimyema compressum.Archives of Microbiology.153(5):496-501.
% `4 U0 p& ?# M1 g3 b: t/ A5.S. Holler, N. Pfennig,1991.Fermentation products of the anaerobic ciliate Trimyema compressum in monoxenic cultures.Archives of Microbiology.156(4):327-334 .! z, ^8 d% S/ E7 n, Y9 H
6.J. W. Rijstenbil, C. Bakker, R. H. Jackson, A. G. A. Merks, P. R. M. de Visscher,1993.Spatial and temporal variation in community composition and photosynthetic characteristics of phytoplankton in the upper Westerschelde estuary (Belgium, SW Netherlands).Hydrobiologia.269-270(1):263-273.+ t9 c7 ?" C# v6 A8 V, S
7.Bettina Meyer-Harms, Falk Pollehne,1998.ALLOXANTHIN IN DINOPHYSIS NORVEGICA (DINOPHYSIALES, DINOPHYCEAE) FROM THE BALTIC SEA.Journal of Phycology.34(2):280–285.
. t& K3 u [0 i% ~2 z8.Catalina Castell Perez, Suzanne Roy, Maurice Levasseur, Donald M. Anderson,1998.CONTROL OF GERMINATION OF ALEXANDRIUM TAMARENSE (DINOPHYCEAE) CYSTS FROM THE LOWER ST. LAWRENCE ESTUARY (CANADA).Journal of Phycology.34(2):242–249.0 U+ [9 {; ^( n. }
9.Teresa Cruz and Jorge Araújo,1999.Reproductive Patterns of Pollicipes pollicipes (Cirripedia: Scalpellomorpha) on the Southwestern Coast of Portugal.Journal of Crustacean Biology.19(2):260-267./ @- Z+ b( z7 x- m1 P& c
10.Michael Hust, Wolfgang E Krumbein, Erhard Rhiel,1999.An immunochemical in situ approach to detect adaptation processes in the photosynthetic apparatus of diatoms of the Wadden Sea sediment surface layers.Journal of Microbiological Methods.38(1–2):69–80. A$ E+ q0 e! r' \0 T
11.Christine Dupuy, Solange Le Gall, Hans J. Hartmann, Martine Bréret,1999.Retention of ciliates and flagellates by the oyster Crassostrea gigas in French Atlantic coastal ponds: protists as a trophic link between bacterioplankton and benthic suspension-feeders.Marine Ecology Progress Series.177:165-175.
# b3 ]. M5 s- e# {/ _% V( m12.A. Tewari, H.V. Joshi, R.H. Trivedi, V.G. Sravankumar, C. Raghunathan, Y. Khambhaty, O.S. Kotiwar, S.K. Mandal,2001.The Effect of Ship Scrapping Industry and its Associated Wastes on the Biomass Production and Biodiversity of Biota in in situ Condition at Alang.Marine Pollution Bulletin.42(6):461–468.4 \! c- @& V0 X
13.Hera Karayanni, Urania Christaki, France Van Wambeke, Andrew P. Dalby,2004.Evaluation of double formalin—Lugol's fixation in assessing number and biomass of ciliates: an example of estimations at mesoscale in NE Atlantic.Journal of Microbiological Methods.56(3):349–358.
1 j5 o( G+ T5 O4 O14.EI Ohimain, TOT Imoobe & MO Benka-Coker,2005.The impact of dredging on macrobenthic invertebrates in a tributary of the Warri River, Niger delta.African Journal of Aquatic Science.30(1):49-53.% q! B- d% A6 p! {) L3 @) a2 w+ a
15.Laurent Seuront, Dorothée Vincent, James G. Mitchell,2006.Biologically induced modification of seawater viscosity in the Eastern English Channel during a Phaeocystis globosa spring bloom.Journal of Marine Systems.61(3–4):118–133.
/ E* K; a! |0 N+ c16.Wim A.M. Hijnen, Yolanda J. Dullemont, Jack F. Schijven, Anke J. Hanzens-Brouwer, Martine Rosielle, Gertjan Medema,2007.Removal and fate of Cryptosporidium parvum, Clostridium perfringens and small-sized centric diatoms (Stephanodiscus hantzschii) in slow sand filters.Water Research.41(10):2151–2162.8 A7 D ~0 V2 W
17.Géraldine Sarthou, Dorothée Vincent, Urania Christaki, Ingrid Obernosterer, Klaas R. Timmermans, Corina P.D. Brussaard,2008.The fate of biogenic iron during a phytoplankton bloom induced by natural fertilisation: Impact of copepod grazing.Deep Sea Research Part II: Topical Studies in Oceanography.55(5–7):734–751.; s' X7 E; V( R4 k% ]
18.Damir Viličić, Tamara Djakovac, Zrinka Burić, Sunčica Bosak,2009.Composition and annual cycle of phytoplankton assemblages in the northeastern Adriatic Sea.Botanica Marina.52(4):291–305.
9 z- ]+ b# C. Z. }, M+ g19.Fedekar F. Madkour, Mohsen M. El-Sherbiny and Maher A. Aamer,2010.Phytoplankton population along certain Egyptian coastal regions of the Red Sea.Egypt J. Aquat. Biol. & Fish..14(2):95-109.
1 k1 V$ n# t+ J8 L& p' J) f3 W6 A20.Mianrun Chena, Bingzhang Chena, Paul Harrisonb, Hongbin Liu,2011.Dynamics of mesozooplankton assemblages in subtropical coastal waters of Hong Kong: A comparative study between a eutrophic estuarine and a mesotrophic coastal site.Continental Shelf Research.31(10):1075–1086.7 |' `- ]5 r8 h
21.Germán A. Kopprio, Gerhard Kattner, Martin Graeve, R. Hugo Freije, Rubén J. Lara,2012.Exceptional lipid storage mode of the copepod Boeckella poopoensis in a pampean salt lake, Argentina.Aquatic Biology.15:275-281.
0 h/ O# d4 |$ P' e- y6 \22.Dongyan Liu, Yajun Shi, Baoping Di, Qianli Sun, Yujue Wang, Zhijun Dong, Hongbing Shao,2012.The impact of different pollution sources on modern dinoflagellate cysts in Sishili Bay, Yellow Sea, China.Marine Micropaleontology.84–85:1–13.
2 A8 j( C" k% j0 F; G6 `7 V23.Daniel Remias, Andreas Holzinger, Siegfried Aigner, Cornelius Lütz,2012.Ecophysiology and ultrastructure of Ancylonema nordenskiöldii (Zygnematales, Streptophyta), causing brown ice on glaciers in Svalbard (high arctic).Polar Biology.35(6):899-908.
& O1 a: G, y* |24.F.S. Tahami, A.G. Mazlan, H. Negarestan, Sh. Najafpour, W.W.M. Lotfi and G.D. Najafpour,2012.Phytoplankton Combination in the Southern Part of Caspian Sea.World Applied Sciences Journal.16(1): 99-105.; h3 @' S! u m4 X: e: D1 u% h
25.Amir Abbas Bazyar Lakeh, Werner Kloas Rainer Jung, Ra’anan Ariav, Klaus Knopf,2013.Low frequency ultrasound and UV-C for elimination of pathogens in recirculating aquaculture systems.Ultrasonics Sonochemistry.20(5):1211–1216.% K8 W2 ?" E2 p' g, q B* y
3 G {. I2 ^) Q( l) ~& X0 r
" P T5 u. e9 m" Y9 T F更多关键字: 浮游植物计数框,藻类计数器,浮游植物计数器, Kolkwitz浮游植物计数框,浮游生物计数框
' M) q N5 Y# _* L& Z, I# n, `( J
' ]) O: h- C8 u8 ^- R0 L. n+ o! `" ?
1 X) ?% O9 X* I% i
<strong> |
