测速范围:0.04~10.Om/s % L1 V" {' k( E9 ]3 t% @9 M: F+ v
工作水深:0.2~40m 8 X& ?0 w) A9 v' f
信 号 数:20转1信号
7 Q% C3 D+ e4 w特 点:量程大,高中低速兼顾. + _9 g" d2 q3 J+ k) E( L3 h
用 途:可用于江河等高、中、低流速及电站、溢洪道的高流速测量.
. V+ V1 }2 p7 @* G# _全套仪器:流速仪主机需配CG20型测杆、流速仪和信号线等使用.
8 ]) W( V1 {0 M! dMeasuring range: 0.04~10.Om/s & x( u/ O& F3 M- N6 l
Water depth: 0.2~40m
# n s5 b5 U- M- v5 VFeatures: large measurements range.
- U5 O6 `6 U: `( U% aApplication: It is widely used for measurements of the flow velocity and high flow velocity in rivers、lakes、 reservoirs, pressure conduits and spillway of hydropower stations.
5 }6 q2 [' T$ O' h0 s) RNotes: The Current Meter needs CG20 wading rod、 monitor、 wire for use. , w+ d. x2 T) [1 Q+ c+ T' d
转载自:化工仪器网 |
