测速范围:0.04~10.Om/s
+ u" C) F w* q# J- M! ]! U- n工作水深:0.2~40m
c5 ]) t5 x8 D3 C" H信 号 数:20转1信号
# p' K+ F4 v- H) _4 g特 点:量程大,高中低速兼顾.
6 B1 V! j |+ h" R% ^" i6 |用 途:可用于江河等高、中、低流速及电站、溢洪道的高流速测量. : G+ O* ?9 p4 f5 r& P6 p; X3 v2 R9 q
全套仪器:流速仪主机需配CG20型测杆、流速仪和信号线等使用.( D+ f( d2 ]" ?5 C
Measuring range: 0.04~10.Om/s o: U1 T* P# s$ g u
Water depth: 0.2~40m
8 v- G9 V w$ i4 _, f1 r. f+ FFeatures: large measurements range. ) i# J& I; r' X- m6 t2 Q
Application: It is widely used for measurements of the flow velocity and high flow velocity in rivers、lakes、 reservoirs, pressure conduits and spillway of hydropower stations.
) }6 `7 C$ ^% Z; j4 Y3 g4 ]Notes: The Current Meter needs CG20 wading rod、 monitor、 wire for use.
% } ^3 Q, G% O7 N$ ~- p; K
7 g' M" @: j9 t转载自:化工仪器网 |
