【浮游生物类仪器】德国HYDRO-BIOS公司 浮游动物计数框
德国HYDRO-BIOS公司——浮游动物计数框8 c& e/ C- _' |5 a3 Z/ j+ X# {
Counting Chamber for zooplankton
1 o( Z8 L2 ?/ e
2 j- b& ?1 t1 T9 _
  j. {& K- `9 I1 y8 Q1 A
- _2 Q' x1 g; p3 f2 k) m3 z
& i- A1 u* P% Y/ E. a( A
浮游动物计数框用于在体式显微镜底下对浮游动物进行观察计数。浮游动物计数框由树脂材料制成,底面抛光,具有较好的透明度,可将其放置到常规显微镜上对浮游动物进行观察。
6 B' T4 f9 H: m0 X* U
9 ?1 l8 t* Q) N- O* g
" @1 J; o, T0 Q1 a9 _5 W4 @5 o2 }
+ N& j; W/ N7 m* s/ d" T* r
; F& W: i# K. ?5 D2 f& i( Q
浮游动物计数框订购指南:. z5 |9 ]: r* k; {9 h
浮游动物计数框由树脂材料制成,底面抛光,具有很好的透明度4 y9 C7 v, z8 y( H; w8 z& I  F
2 t3 S* C' F0 C* I
4 K# X* s$ E: D        435 010     浮游动物计数框尺寸40×70mm,容纳样品量约9ml
$ }; p. r- j$ [: b
0 h0 g/ g1 p4 r% S7 x( {/ Q
& ]0 U; H1 E$ U) n1 ^( P        435 011      浮游动物计数框尺寸80×100mm,容纳样品量约22ml/ A7 K& c1 G# o* x* ^2 [
        435 011A   浮游动物计数框尺寸80×100mm,容纳样品量约6×5.4ml& ]$ S1 b- I1 i; E( X9 x9 r7 f
        435 011B   浮游动物计数框尺寸80×100mm,容纳样品量约12×2.4ml
7 J! s* g4 p; ]  [        435 011C   浮游动物计数框尺寸80×100mm,容纳样品量约30×0.8ml
  d5 o6 U, s5 U! ?# \% Z# r
) i( z! S' S7 y' H
( X, Z% d4 K. f% ?2 B
        435 012    浮游动物计数框尺寸80×140mm,容纳样品量约70ml
0 `' p. h+ H) g9 A) j4 x# w! D" U2 `" D/ y" Q; g! }2 P
/ w$ Q6 w4 d! r8 Q" i, ~代表文献:
$ L' X8 r6 _4 a: `5 l* Q5 [6 `5 K6 e1.Manfred Rolke and Jürgen Lenz,1984.Size structure analysis of zooplankton
1 B0 v3 L* R7 e9 N* i) psamples by means of an automated image analyzing system.Journal of Plankton Research.6(4): 637-645./ j! Q& d5 X" S2 N5 M0 R9 T6 z
2.Austin B.M. Egborge and Prekeyi Tawari,1987.The rotifers of Warri River, Nigeria.Journal of Plankton Research.9(1):1-13.
) R5 Q; V. M1 {3 T+ l( ^+ @6 v3.J.W. Rijstenbil,1987.Phytoplankton composition of stagnant and tidal ecosystems in relation to salinity, nutrients, light and turbulence.Netherlands Journal of Sea Research.21(2):113–123.
* s+ R( |  z5 h4.S. Wagener, C. F. Bardele, N. Pfennig,1990.Functional integration of Methanobacterium formicicum into the anaerobic ciliate Trimyema compressum.Archives of Microbiology.153(5):496-501.; V- @$ L) W, y6 _1 X
5.S. Holler, N. Pfennig,1991.Fermentation products of the anaerobic ciliate Trimyema compressum in monoxenic cultures.Archives of Microbiology.156(4):327-334 .
$ a* O: G  g- y( R& Q, R6.J. W. Rijstenbil, C. Bakker, R. H. Jackson, A. G. A. Merks, P. R. M. de Visscher,1993.Spatial and temporal variation in community composition and photosynthetic characteristics of phytoplankton in the upper Westerschelde estuary (Belgium, SW Netherlands).Hydrobiologia.269-270(1):263-273.
+ H& l/ m. d$ c# W7.Bettina Meyer-Harms, Falk Pollehne,1998.ALLOXANTHIN IN DINOPHYSIS NORVEGICA (DINOPHYSIALES, DINOPHYCEAE) FROM THE BALTIC SEA.Journal of Phycology.34(2):280–285.
5 G0 o3 q. ~. E7 _8.Catalina Castell Perez, Suzanne Roy, Maurice Levasseur, Donald M. Anderson,1998.CONTROL OF GERMINATION OF ALEXANDRIUM TAMARENSE (DINOPHYCEAE) CYSTS FROM THE LOWER ST. LAWRENCE ESTUARY (CANADA).Journal of Phycology.34(2):242–249.
3 X8 s0 a# e" q3 ]( h$ k9.Teresa Cruz and Jorge Araújo,1999.Reproductive Patterns of Pollicipes pollicipes (Cirripedia: Scalpellomorpha) on the Southwestern Coast of Portugal.Journal of Crustacean Biology.19(2):260-267.# k" e, t  Q1 q) x
10.Michael Hust, Wolfgang E Krumbein, Erhard Rhiel,1999.An immunochemical in situ approach to detect adaptation processes in the photosynthetic apparatus of diatoms of the Wadden Sea sediment surface layers.Journal of Microbiological Methods.38(1–2):69–80.
" O5 h# U7 C1 l# b11.Christine Dupuy, Solange Le Gall, Hans J. Hartmann, Martine Bréret,1999.Retention of ciliates and flagellates by the oyster Crassostrea gigas in French Atlantic coastal ponds: protists as a trophic link between bacterioplankton and benthic suspension-feeders.Marine Ecology Progress Series.177:165-175.
7 `  U3 U( q3 F9 N& @12.A. Tewari, H.V. Joshi, R.H. Trivedi, V.G. Sravankumar, C. Raghunathan, Y. Khambhaty, O.S. Kotiwar, S.K. Mandal,2001.The Effect of Ship Scrapping Industry and its Associated Wastes on the Biomass Production and Biodiversity of Biota in in situ Condition at Alang.Marine Pollution Bulletin.42(6):461–468.. d. @& E! j0 H! g  e( d
13.Hera Karayanni, Urania Christaki, France Van Wambeke, Andrew P. Dalby,2004.Evaluation of double formalin—Lugol's fixation in assessing number and biomass of ciliates: an example of estimations at mesoscale in NE Atlantic.Journal of Microbiological Methods.56(3):349–358.* A  a  {+ y: W/ t* s7 C7 M
14.EI Ohimain, TOT Imoobe & MO Benka-Coker,2005.The impact of dredging on macrobenthic invertebrates in a tributary of the Warri River, Niger delta.African Journal of Aquatic Science.30(1):49-53.
! Z5 Y5 R/ ^4 t& L$ ~# c/ |7 [15.Laurent Seuront, Dorothée Vincent, James G. Mitchell,2006.Biologically induced modification of seawater viscosity in the Eastern English Channel during a Phaeocystis globosa spring bloom.Journal of Marine Systems.61(3–4):118–133.) o1 |9 v: _" q  I
16.Wim A.M. Hijnen, Yolanda J. Dullemont, Jack F. Schijven, Anke J. Hanzens-Brouwer, Martine Rosielle, Gertjan Medema,2007.Removal and fate of Cryptosporidium parvum, Clostridium perfringens and small-sized centric diatoms (Stephanodiscus hantzschii) in slow sand filters.Water Research.41(10):2151–2162., |6 J  k6 t3 A5 j2 n
17.Géraldine Sarthou, Dorothée Vincent, Urania Christaki, Ingrid Obernosterer, Klaas R. Timmermans, Corina P.D. Brussaard,2008.The fate of biogenic iron during a phytoplankton bloom induced by natural fertilisation: Impact of copepod grazing.Deep Sea Research Part II: Topical Studies in Oceanography.55(5–7):734–751.
0 j- u$ Z$ |$ Z2 Y* a% `" ?18.Damir Viličić, Tamara Djakovac, Zrinka Burić, Sunčica Bosak,2009.Composition and annual cycle of phytoplankton assemblages in the northeastern Adriatic Sea.Botanica Marina.52(4):291–305.8 a' `( }* @0 F! e; o; F1 ^5 Y, N* d
19.Fedekar F. Madkour, Mohsen M. El-Sherbiny and Maher A. Aamer,2010.Phytoplankton population along certain Egyptian coastal regions of the Red Sea.Egypt J. Aquat. Biol. & Fish..14(2):95-109., j" Z7 h8 w  w/ n7 x4 j
20.Mianrun Chena, Bingzhang Chena, Paul Harrisonb, Hongbin Liu,2011.Dynamics of mesozooplankton assemblages in subtropical coastal waters of Hong Kong: A comparative study between a eutrophic estuarine and a mesotrophic coastal site.Continental Shelf Research.31(10):1075–1086.. p% M- _& p7 B; d/ s; x2 D4 n
21.Germán A. Kopprio, Gerhard Kattner, Martin Graeve, R. Hugo Freije, Rubén J. Lara,2012.Exceptional lipid storage mode of the copepod Boeckella poopoensis in a pampean salt lake, Argentina.Aquatic Biology.15:275-281.
' X( Z+ D' E% `% T* s. L22.Dongyan Liu, Yajun Shi, Baoping Di, Qianli Sun, Yujue Wang, Zhijun Dong, Hongbing Shao,2012.The impact of different pollution sources on modern dinoflagellate cysts in Sishili Bay, Yellow Sea, China.Marine Micropaleontology.84–85:1–13.3 d; o7 L9 v0 x. }* X4 v
23.Daniel Remias, Andreas Holzinger, Siegfried Aigner, Cornelius Lütz,2012.Ecophysiology and ultrastructure of Ancylonema nordenskiöldii (Zygnematales, Streptophyta), causing brown ice on glaciers in Svalbard (high arctic).Polar Biology.35(6):899-908.
7 h/ a. v% [/ s24.F.S. Tahami, A.G. Mazlan, H. Negarestan, Sh. Najafpour, W.W.M. Lotfi and G.D. Najafpour,2012.Phytoplankton Combination in the Southern Part of Caspian Sea.World Applied Sciences Journal.16(1): 99-105.
3 o0 q* g( w  J3 C3 m25.Amir Abbas Bazyar Lakeh, Werner Kloas Rainer Jung, Ra’anan Ariav, Klaus Knopf,2013.Low frequency ultrasound and UV-C for elimination of pathogens in recirculating aquaculture systems.Ultrasonics Sonochemistry.20(5):1211–1216.
" r# V9 M) n# |$ P1 J( e  W7 C- z+ ]9 ]" K0 A. L
4 J2 u8 E1 j+ k4 P1 ^
更多关键字: 浮游动物计数框,浮游生物计数框,浮游生物观察组件
( d  Z5 v2 \+ h* M; B' b# k& P9 W" v* G2 o
1 y: q% w: j9 J: M8 G% a% M* e
7 ^: I7 n9 ?. U. ^<strong>
