2 `$ J) t- n* g* k
~! Q5 Y* s# e8 l: h, W: a
1822号台风“山竹”引起的南海北部热异常- w2 t- E0 e. }
全文请用PC端下载 地址:
, g& ]7 F: U& j2 W4 n1 S- q) u8 C3 R5 Q
http://www.hyyb.org.cn/Magazine/Show.aspx?ID=3465
" H8 B4 W5 k6 |0 @* r% h读书小笔记
: G5 S# f6 F9 h; o4 Q作者:钟天任1 2 章鑫1 2 邓志辉1 2 严兴1 2; V) n8 u8 P% F
单位:1. 广东省地震局, 广东 广州 510070;) l! }0 H' N* ^) Q" V( g9 v6 T
2. 南方海洋科学与工程广东省实验室(珠海), 广东 珠海 519080
+ L- a. @* l) i分类号:P731.114 @0 j" P5 u+ g
出版年·卷·期(页码):2023·40·第二期(11-21): N$ ?" O, t O& w! S2 A% {) l
摘要:1822号台风”山竹”是2018年登陆华南沿海的最强台风,给华南地区带来了强风暴雨等严重灾害。本文采用了欧洲中期天气预报中心海表温度(Sea Surface Temperature,SST)日值产品和中国风云系列卫星的热红外亮温数据,对数据进行均值残差处理、小波分析和相对功率谱(Relative Power Spectrum,RPS)估计,得到台风发展过程的SST变化以及亮温RPS信息。对SST和亮温RSP的综合分析结果表明:台风生成前和活动期间在南海北部引起了SST增温异常和过境后的冷迹,也出现了21 d和16 d特征周期的热辐射异常;异常过程反映了台风与海洋的热交换过程,即热交换开始于台风生成之前,促使台风向南海北部移动,台风过境后大幅度降温;台风产生的热异常集中在南海北部,但主要分布在台风路径南侧的海面范围,这可能与台风过程中的海-陆、海-气热交换密切相关。
! t" y, t1 V" `% d( I _( l关键词:台风“山竹” 南海北部 海表温度 相对功率谱( k5 a+ z3 Y/ P' l% \- ~) e' O1 w4 [
Abstract:Typhoon "Mangkhut" (No. 1822) was the strongest typhoon that landed on the coast of South China in 2018 and caused severe disasters such as heavy storms and rains. In this paper, the daily sea surface temperature (SST) of the European Centre for Medium-Range Weather Forecasts and the thermal infrared brightness temperature data of China's FY-E satellites are processed by using mean residual processing, wavelet analysis and relative power spectrum estimation, and the SST variation and relative power spectrum (RPS) during the typhoon development process are obtained. The results of comprehensive analysis of SST and RPS show that SST is anomaly warm both before the typhoon generates and when the typhoon is active, while the SST decreases after the typhoon passes through the northern South China Sea. Moreover, there shows thermal radiation anomaly with characteristic periods of 21 days and 16 days. The abnormal processes reflect the heat exchange between typhoon and the ocean surface, which starts before the formation of typhoon and promotes typhoon to move to the northern South China Sea. It causes a significant cold drop in temperature after the typhoon passes through. The thermal anomaly caused by the typhoon is concentrated in the northern part of the South China Sea, especially over the sea surface on the south side of the typhoon path, which may be closely related to the sea-land and seaair heat exchange during the typhoon process.
4 L) F# x* Y! G4 n' S4 e5 NKey words:typhoon "Mangkhut"; northern South China Sea; sea surface temperature; relative power spectrum: l" b5 C0 C) E6 k5 e; R
4 r5 r5 V2 s- ~. c! ]
" d: |' `( J2 `5 v5 g4 o! \. G2 O读者也可以通过公众号菜单栏
& W8 g3 o' r( x' s“相关知识”板块进入《当期目录》和《过刊浏览》
N5 h6 S' D7 \5 s3 Z/ S' j查阅详细期刊内容
1 V- ]6 A# E2 ]1 X$ i未来两天海洋环境预报
0 G8 p/ O7 a5 n T7 y预计明天,
4 P9 t9 ]' S* r7 T" P4 i! P0 H; G6 x渤海、黄海有0.6到1米的轻浪;
5 \3 H4 @4 \: \! \2 e. Q% \东海、钓鱼岛附近海域有1.1到2.4米的轻浪到中浪区;
6 c/ E' v# X6 e台湾海峡、台湾以东洋面、巴士海峡有1.5到2.4米的中浪区;% w) u$ ~6 X, p- G0 |! l) z8 V
北部湾有0.8到1.2米的轻浪;
4 S2 o* n1 e) I5 R% f( |4 W南海有1.1到1.9米的轻浪到中浪。
( o9 t/ D9 E/ J3 D! W0 t1 @3 M# C* W预计后天,- b$ S2 ?3 ?" r
我国近海无大浪区。7 b+ k9 p0 f7 b6 d) R1 k
4 h5 ]$ m: K9 G" \: w8 H: v) A5 U- E8 {2 @2 q
2023年5月22~26日西北太平洋海浪数值预报, j! E; y5 ~$ I
美丽海岛海域海况
1 S4 U) }3 ` f预计明天,
1 A. i, Z# r, u7 x; ^& A7 p. o钓鱼岛附近海域有2.3米的中浪,不适宜乘船出行;5 z7 c0 _& R$ {% ^3 o! `2 C
平潭岛附近海域有2米的中浪,东极岛、大陈岛、湄洲岛、东山岛、南澳岛附近海域有1.4~1.7米的中浪,较适宜乘船出行和海岛游玩;
" e$ D3 t/ N% K6 @1 k$ T我国其他各美丽海岛附近海域都是轻浪,海况不错,非常适宜乘船出行和海岛游玩。
+ \% k# T3 h7 _; u2 ?- b" e$ o' t" J
美丽海岛是指以下的35个海岛:
1 \4 G* }% Q: Z" U觉华岛、长山群岛、菩提岛、长岛、刘公岛、灵山岛、秦山岛、连岛、崇明岛、嵊泗列岛、岱山岛、东极岛、普陀山、大陈岛、玉环岛、洞头岛、南麂岛、嵛山岛、三都岛、平潭岛、湄洲岛、东山岛、钓鱼岛、南澳岛、万山群岛、川山群岛、海陵岛、南三岛、东海岛、涠洲岛、分界洲岛、蜈支洲岛、永兴岛、黄岩岛、永暑礁。
E# D- {5 k, B5 r+ p更多滨海旅游预报 尽在中国海洋预报
- f7 k+ k- j- E% \" j4 y: B
9 J8 I9 P2 @" w1 A5 K# f9 T, a! T& i/ r! D! s
PC端可登录中国海洋预报网http://www.oceanguide.org.cn/IndexHome v3 l h9 @! ]4 P$ D6 b7 {
: e8 D- _9 z+ |1 \* a5 U$ u
) b' l. q: m! I9 ` C& W. f
移动端可使用中国海洋预报微信小程序
2 e+ O# y; k' P0 L, ?$ s进入“中国海洋预报”微信小程序+ R; E/ y8 Q4 N
进入“全球海啸预警”微信小程序 |
