《海洋预报》| 警戒潮位核定中重现期高潮位计算方法的探讨
* @5 H& ~* M1 G* a' |' o. _
$ p# ~. a3 i! }$ v
/ f4 M2 O9 w1 B2 d9 k警戒潮位核定中重现期高潮位计算方法的探讨
& J3 s$ ?9 k# }# q& L8 O: ?! C全文请用PC端下载 地址:
- Z8 b) [) ~! Q1 a7 C
1 G/ u9 k" [7 X' k1 i4 ]' X5 o! Uhttp://www.hyyb.org.cn/Magazine/Show.aspx?ID=3480
7 S( t! G9 L  H2 R  ~# J读书小笔记
: N% D% Q$ v2 h: j. e% o作者:赵强 龙绍桥 舒志光 王艳萍
- O9 }4 A0 [+ F" O+ r) ]8 c单位:宁波海洋环境监测中心站, 浙江 宁波 3150126 s' f/ p; C  }0 h
分类号:P731.23
% y6 F( t+ F* }& Y出版年·卷·期(页码):2023·40·第三期(28-34)
% Q0 \2 |% b, q# Y) P. I/ Q* s6 [摘要:针对警戒潮位核定中重现期高潮位计算问题,优化了高潮同步相关法的计算步骤。将核定站年极值高潮位经G-I分布直接得到的重现期高潮位作为客观值,将通过参考站年极值高潮位间接得到的重现期高潮位作为计算结果,以宁波海域湖头渡水文站和乌沙山海洋站、镇海水文站和镇海海洋站、大目涂水文站和石浦海洋站这3对潮位站的实测潮位资料为基础,计算并比较了高潮同步相关法、潮位同步相关法、极值同步差比法和年极值相关法的计算结果误差。结果显示,对于有1个月~5年连续实测潮位资料的核定站,潮位同步相关法计算结果的精确度和稳定性优于高潮同步相关法;对于有5~20年连续实测潮位资料的核定站,当数据年限较长且核定站与参照站同期年极值高潮位呈显著强相关时,年极值相关法的计算结果优于极值同步差比法。9 J: _& }. H5 d! p: q; {
关键词:警戒潮位核定 重现期高潮位 误差分析
  V3 y3 }4 i0 ], Z+ J, K& j0 WAbstract:To estimate tide level in sea level return periods in the warning water level determination, the high tide correlation method are optimized using observation data from three pairs of tide gauge stations located along the coast of Ningbo. Four methods, i. e. the high tide correlation method, the tide level correlation method, the extreme value difference ratio method and the annual extreme value correlation method, are used to calculate the tide level in return periods, and the errors of these methods are compared. The results show that for the tide level data with the length of 1 month to 5 years, both the accuracy and stability of the tide level correlation method are better than those of the high tide correlation method. For the data with the length of 5 to 20 years, the annual extreme value correlation method is better than the extreme value difference ratio method when the correlation of observation data between the determination station and the reference station is strong.
/ d5 \' K  \# l- \' R, z9 _) fKey words:warning water level determination; sea level return periods; error analysis% q0 s* f4 u- R0 c2 x3 t( k
0 ~7 _% T+ t. y( R: L& p
7 q$ u* |3 q3 r5 Q5 C" {& W& X9 I& R
7 h) U8 |  v( u- \
读者也可以通过公众号菜单栏/ i/ U8 N5 O. P4 x. W, s% s8 m
“相关知识”板块进入) k. w- [, R9 C8 [; @" H# L  {
《当期目录》和《过刊浏览》
1 o+ W2 J, m! V9 p" w8 ]8 d& Z( Q查阅详细期刊内容
3 d/ d# D& c+ Q8 \4 }# l7 A' Q未来两天海洋环境预报0 p/ r* {& N! [0 _' }/ `9 {2 y
预计明天,, a) K: X* X7 @- [7 m
渤海有0.6到0.8米的轻浪;
9 Z( i5 d( w) K% m4 j( e! L8 S0 F( h黄海北部有0.6到1米的轻浪;
  y" ]4 Q/ d% S& `黄海南部、东海北部有0.8到1.3米的轻浪到中浪;
% Q, h0 S8 _. Z: N. l' `1 i东海南部、钓鱼岛附近海域有1.2到1.5米的轻浪到中浪;
' D/ @4 P) p; E台湾以东洋面、巴士海峡有1.3到1.8米的中浪;  R" a+ d, Z7 _7 T" @' I# O
台湾海峡、南海北部、北部湾有0.6到1米的轻浪;
3 ?1 ^/ y$ f4 D, y1 Z南海中部有1到1.5米的轻浪到中浪;1 L. \; R7 n2 U8 Z
南海南部有1.3到1.8米的中浪。
8 U$ J/ W3 Q" X6 p& n4 X! u, ~预计后天,
/ k  w" n# W7 @1 p受今年第5号台风“杜苏芮”的影响,菲律宾以东洋面的大浪区维持,浪高6到10米;台湾以东洋面、巴士海峡将生成大浪区,浪高2到3米。9 B8 ^& f2 a: z% X0 E
0 y! @1 P8 A% s3 S, L
& C. B, s$ M3 d0 g& C# t! A
4 D0 B* Y1 N% `* [3 R- ]4 e* C7月22~26日西北太平洋海浪数值预报
% G# J4 l7 r8 x4 e( M* L美丽海岛海域海况
3 `$ R% k) r. v8 y/ ^/ u% @预计明天,6 V) E; g& T4 X1 l
永暑礁附近海域有1.8米的中浪,钓鱼岛附近海域有1.5米的中浪,以上海岛较适宜乘船出行和海岛游玩;
! e( W+ B$ n/ A8 x: o" m7 o我国其他各美丽海岛附近海域都是轻浪,海况不错,非常适宜乘船出行和海岛游玩。
3 F8 [0 v9 ?" \. h2 y5 V! q% G8 `9 v6 j
美丽海岛是指以下的35个海岛:
5 j! S) V% t0 A: S( @觉华岛、长山群岛、菩提岛、长岛、刘公岛、灵山岛、秦山岛、连岛、崇明岛、嵊泗列岛、岱山岛、东极岛、普陀山、大陈岛、玉环岛、洞头岛、南麂岛、嵛山岛、三都岛、平潭岛、湄洲岛、东山岛、钓鱼岛、南澳岛、万山群岛、川山群岛、海陵岛、南三岛、东海岛、涠洲岛、分界洲岛、蜈支洲岛、永兴岛、黄岩岛、永暑礁。
3 K( ~$ S, m7 j0 N3 q6 y, K# K4 F' M更多滨海旅游预报 尽在中国海洋预报/ k4 R' E8 o+ q) }
; w- S1 t; V- U/ @! a  C; ]( B
% F3 N0 N8 q! y. a9 H- r% q
" K* s2 n4 C/ QPC端可登录中国海洋预报网http://www.oceanguide.org.cn/IndexHome' h0 C, w3 B$ ~
: ~4 c/ l1 }7 y% z
# @  S/ E3 D4 ^! V/ V7 N3 _0 T2 F# z7 J- c0 d  X: H/ Y9 z
移动端可使用中国海洋预报微信小程序
8 |1 Q. [  Y6 K; ~( M  m进入“中国海洋预报”微信小程序
$ x, I- Y  c  |5 H" X0 }) i/ Z进入“全球海啸预警”微信小程序
di86qae5r2
活跃在2021-7-25
