《海洋预报》 | 江苏沿海海域潮流能资源分析评估
) P* o. W$ }1 E2 }  r) j$ k% F
/ R4 f+ k) q! h9 U" U7 P" c- @2 A9 C1 N( a3 T# j% i
" l: m  _5 B8 d. j/ h
& G' D0 Z  i# z1 m; Q$ S
7 W2 v% D8 V9 x: L江苏沿海海域潮流能资源分析评估0 U0 q9 ^' H: X( D& s" x) h
全文请用PC端下载 地址:% z" {/ @5 L( l; o& O
1 i& |$ @5 R8 E' {4 i, e' c" [
http://www.hyyb.org.cn/Magazine/Show.aspx?ID=3495
4 `4 Z, }. ]6 p2 _2 ^+ q读书小笔记
  Z7 _9 j4 t* N) j6 g& \! ?作者:吉会峰 高清清 宋心刚 丁言者 杨波 刘吉堂
# A3 P1 o; T' p: u: h1 j单位:自然资源部南通海洋中心, 江苏 南通 226002" w1 d$ l+ U0 R/ y9 D  E( ?
分类号:P743.15 A2 D- ]* M" c8 f
出版年·卷·期(页码):2023·40·第四期(47-55)
% x& `0 X" n6 n# i# d- u3 I摘要:建立了江苏沿海二维潮流数学模型,并采用观测资料对模型进行验证,验证结果表明该模型具有较高的可信度。基于模型一年的计算结果,分析了江苏海域的流速特征;计算潮流能平均功率密度和年有效流时,并给出空间分布特征。结果显示:除连云港海域外,江苏沿海大部分海域潮流能功率密度在200 W/m2以上,潮流能年有效流时大于2 400 h,在滨海、大丰、东台海域存在潮流能功率密度高值区,辐射沙洲个别水道区域最大值可达1 450 W/m2;废黄河口、辐射沙洲北部、东部、南部4个特征断面上的潮流能资源理论蕴藏量分别为92 MW、157 MW、41 MW和40 MW。+ e4 l- r: n# s- W" k+ ^) p6 h
关键词:江苏 潮流能 理论蕴藏量 资源评估
7 V, E/ g3 ]- |. P! y0 C8 Q; L9 n$ T
Abstract:A two-dimensional tidal current numerical model in Jiangsu coast area is established and verified using the measured data. The verification shows that the model result is in good agreement with the measured values. Based on the model result for a whole year, the ocean velocity characteristics of Jiangsu coast area are analyzed, and the tidal current energy power density and significant hours are calculated. The results show that, except Lianyungang coast area, the tidal current energy power density in most of Jiangsu coastal areas is more than 200 W/m2, and the annual significant hours is more than 2 400 h. High power density occurs in Binhai, Dafeng and Dongtai sea areas, and the maximum value reaches 1 450 W/m2 in specific channel of radial sand ridges. The theoretical reserves of tidal current energy resources on four characteristic sections are 92 MW, 157 MW, 41 MW and 40 MW respectively.
1 \1 A- j! a+ p( D% S' P: _9 v. eKey words:Jiangsu; tidal current energy; theoretical reserves; resource assessment' w+ ]8 d5 w% Y& ?+ O
& h3 M, _* f8 A2 ^% l. `* O
/ E% h! G% }4 u- a' C! m
5 u' W( v& }+ a9 u# X
读者也可以通过公众号菜单栏
+ Z; A7 C, C$ N/ E2 U6 H- I; v1 ]“相关知识”板块进入. l/ c( s! g8 g5 n5 M5 a! S4 e
《当期目录》和《过刊浏览》
' |% J# Q0 V5 I5 R; V查阅详细期刊内容
7 G. l7 }( y% }$ h未来两天海洋环境预报* y9 W( s8 f, c: V# `! _  i% o/ i
预计明天,
% ]. }' H+ v3 R+ Z& ]渤海、黄海北部有0.4到0.9米的小浪到轻浪;
- j) I! w% |+ {黄海南部有0.7到1.5米的轻浪到中浪;1 T. Z" Q" z, U  F1 \
东海北部有1.1到1.6米的轻浪到中浪;
! f2 a( y+ E. q4 K) j" t东海南部、钓鱼岛附近海域、台湾海峡、巴士海峡、台湾以东洋面有1.3到1.8米的中浪;
4 k/ J% j6 ?3 E# K. y9 o( s南海、北部湾有1.5到2.4米的中浪区。
/ D" f6 R9 {4 [$ b; n: A( ]3 o& [预计后天,
1 a* t8 v+ I3 C- [2 f  v- h南海将生成新的大浪区,浪高2到3米;
. L: X/ B7 O9 v% L; G# e# J/ e北部湾将生成新的大浪区,浪高2.1到2.7米。2 a$ E3 ]+ v! h# n- m# ~  [
5 r. t; N! M; m" o
) M$ b* z# M% K3 v' H) J; M8 g- h4 r
' _* F5 ?  m) K! j
9月24~28日西北太平洋海浪数值预报" l% B8 _3 {4 @) v( x
美丽海岛海域海况
8 f+ K2 M% \1 I5 Y- G( q/ g! R* |预计明天,
. B1 j+ D( P' h) n永暑礁附近海域有2.5米的大浪,分界洲岛、蜈支洲岛、永兴岛附近海域有2.2~2.4米的中浪,以上海岛不适宜乘船出行。
; U9 \* }  `+ u南三岛、东海岛附近海域有1.9米的中浪,灵山岛、东极岛、平潭岛、湄洲岛、钓鱼岛、川山群岛、海陵岛、涠洲岛附近海域有1.3~1.7米的中浪,这些海岛较适宜乘船出行和海岛游玩;3 ]# i$ z6 `3 K% V, d
" ?7 }4 S% X, ~( ~我国各美丽海岛附近海域都是轻浪,海况不错,非常适宜乘船出行和海岛游玩。
. C# K, m* Z$ T. q% j
% Z; I& ]  K5 v% [% d* f1 P美丽海岛是指以下的35个海岛:
6 n+ g& Q7 z7 u5 m; S" a1 \: x觉华岛、长山群岛、菩提岛、长岛、刘公岛、灵山岛、秦山岛、连岛、崇明岛、嵊泗列岛、岱山岛、东极岛、普陀山、大陈岛、玉环岛、洞头岛、南麂岛、嵛山岛、三都岛、平潭岛、湄洲岛、东山岛、钓鱼岛、南澳岛、万山群岛、川山群岛、海陵岛、南三岛、东海岛、涠洲岛、分界洲岛、蜈支洲岛、永兴岛、黄岩岛、永暑礁。/ @+ _: D- R8 [
更多滨海旅游预报 尽在中国海洋预报
# ]( p/ L* V3 d
7 G; U) Q1 X( x" ^, }. M% L
7 ~0 ^1 ?- d" a! y- k  J  J
, _, C- B( t" g
PC端可登录中国海洋预报网http://www.oceanguide.org.cn
  I& \: t* Z$ M
% V; u6 f  W9 E& G$ Q( f7 w
5 t( r/ C' c# k) W: i, V% c2 ^; c7 f- }. A, O
移动端可使用中国海洋预报微信小程序
# G8 g2 ~$ ^0 h, g9 T! z3 b进入“中国海洋预报”微信小程序% C! G5 V  e$ t) f
进入“全球海啸预警”微信小程序
di86qae5r2
活跃在2021-7-25
