) Q7 M, f; M! q( b/ Z& f
. \3 E, _) `) g3 ^# \强潮河口盐水入侵特征数值模拟研究
* r- ~6 J0 F# J2 b% k8 b$ G& M" R: x' L; c
全文请用PC端下载 地址:
. @- C/ F; c7 d* p1 S' ~- ?3 r0 g4 _, a1 x* w, q7 K9 u3 z
http://www.hyyb.org.cn/Magazine/Show.aspx?ID=35104 p- E+ X: r( |; _- m
读书小笔记* U) Z% ?" Q4 v
作者:路川藤1 2 钱明霞1 2 夏威夷1 2 丁伟1 2 丁佩18 J a6 k/ w; T0 B* r2 y
单位:1. 南京水利科学研究院, 江苏 南京 210029;
6 v/ i8 ^2 C- h8 V* O1 s8 @8 @2. 水文水资源与水利工程科学国家重点实验室, 江苏 南京 2100983 J9 u4 Y* |1 h3 v5 x
分类号:P731.12# x. i% D, Q r/ F. J4 w
出版年·卷·期(页码):2023·40·第五期(56-65)
; A7 z) h' D7 {$ A5 @# A; N8 l摘要:以强潮河口——椒江河口为研究对象,通过数学模型研究不同径流、潮差条件下的盐水入侵特征,明晰强潮河口的盐水入侵特性,为相关科学研究以及工程建设提供技术支撑和依据。结果表明:椒江为枯季低流量(10 m3/s)时,0.1‰盐水可以上溯至始丰溪与永安溪的交汇处三江村附近,5‰盐水可以上溯至八仙岩附近,椒江达洪峰流量(3 000 m3/s)时,海门以上河段的盐水浓度均小于0.1‰;在径流变化潮差不变条件下,盐水上溯距离变化梯度涨憩大于落憩,小潮大于大潮,随着径流量的增大,盐水上溯距离变化梯度逐渐增大;在潮差变化径流不变条件下,盐水上溯距离变化区间呈线性增长趋势,随着径流量的增大,同等潮差下的盐水上溯距离变化区间逐渐减小;拟合出了椒江河口盐水最大上溯距离与径流、潮差的函数关系式,预测值偏差在2%~6%,可为椒江其他相关盐水研究提供借鉴。3 k' A/ b! X6 M V* A+ z
关键词:强潮河口 椒江 盐水入侵 数值模拟 CJK3D-WEM8 Q( K0 d: c, l
Abstract:Taking a strong tidal estuary (Jiaojiang Estuary) as the research object, this paper studies the salt water intrusion characteristics under different runoff and tidal range conditions through mathematical models, and clarifies the salt water intrusion characteristics at strong tidal estuary, to provide technical support and basis for relevant scientific research and engineering construction. It is found that when Jiaojiang River has low discharge (10 m3/s) in dry season, 0.1‰ salt water can be tracked upstream to the Sanjiang village and 5‰ salt water can be tracked upstream to the vicinity of Baxianyan. When Jiaojiang River is at peak discharge (3000 m3/s), the salt water concentration is less than 0.1‰ in the river regions upstream of Haimen. Under the condition of different runoff but same tidal range, the variation gradient of salt water upstream tracking distance in flood slack is greater than that in ebb slack, and neap tide is greater than spring tide. With the increase of runoff, the variation gradient of salt water upstream tracking distance increases gradually. Under the condition of different tidal range but same runoff, the variation range of salt water upstream tracking distance increases linearly. With the increase of runoff, the variation range of salt water upstream tracking distance under the same tidal range decreases gradually. The functional relationship between the maximum upstream tracking distance of salt water in Jiaojiang Estuary and runoff and tidal range is fitted, and the deviation of the predicted value according to the relationship is between 2% and 6%, which can provide reference for other relevant salt water researches in Jiaojiang River.! ^ d: _' O+ r1 p5 h( t, l
Key words:strong tidal estuary; Jiaojiang; salt water intrusion; numerical simulation; CJK3D-WEM
6 B7 \7 \! C/ r, \ Q' S+ W" y, D' h" K
" P& W+ _; U1 h" A读者也可以通过公众号菜单栏7 p- }3 {! u- U+ c. l
“相关知识”板块进入+ R! H2 `0 |! p
《当期目录》和《过刊浏览》 V) o. c: r$ z1 A! @
查阅详细期刊内容
% O3 I2 u1 J% k8 l$ o# v. s" V未来两天海洋环境预报
$ J5 Z- W9 j/ w; A) L预计明天,
0 a, w1 v7 G, [& `3 n, K0 k9 ^渤海有1到1.8米的轻浪到中浪;# ]/ c3 L( Y( [# t& j
黄海北部有1.3到2米的中浪区;
- h9 k- J% l3 ^; z) z黄海南部、东海有2到2.8米的中浪到大浪区;8 Z, `6 F3 f, h0 S) v4 l3 t
台湾海峡有1.5到2.3米的中浪区;
7 r0 F. T5 r+ y6 R7 K z$ P) D台湾以东洋面、巴士海峡有2.5到3.3米的大浪区; u+ c& a! I3 y8 I/ q2 ^' n! L9 }& k
南海有2到2.8米的中浪到大浪区;& N2 {- s, s9 C, \: F$ T
北部湾有1.5到2.3米的中浪区。
) X: K1 z+ ?3 y# P( ~预计后天,$ s0 [2 k0 S# ?
黄海南部、东海的大浪区维持,浪高1.8到2.5米;
+ `! M: x+ {$ w) O' l6 f5 e1 B$ ?' D台湾以东洋面、巴士海峡的大浪区维持,浪高2.5到3.5米;
. \+ J7 E0 w4 V# C. Z8 {& l, M* n I南海的大浪区维持,浪高2到3.5米。% c+ v0 Y# P, x# Y/ _9 i# \
. o6 e: d& v$ V3 ^3 u
4 [: q& |; w. v12月5~9日西北太平洋海浪数值预报
8 t& m6 x* k- h% Q; W( B& z美丽海岛海域海况8 j* L+ U' l5 f0 J8 l5 G& U6 W6 b
预计明天,
7 O/ i% p; u$ h4 y8 \% P+ y% W0 R7 G钓鱼岛、永兴岛、黄岩岛、永暑礁附近海域有1.8~1.9米的中浪,东极岛、平潭岛、湄洲岛、万山群岛、川山群岛、分界洲岛、蜈支洲岛附近海域有1.3~1.7米的中浪,这些海岛较适宜乘船出行和海岛游玩;
0 T8 z+ a& d7 t# Q6 Q' ?5 M' p8 V g' O3 e6 M3 @4 u
我国其他美丽海岛附近海域都是轻浪,海况不错,非常适宜乘船出行和海岛游玩。3 H5 _8 P p. F% }5 h7 b# _
. p4 c$ D# V. u( x+ P8 y- |- n
美丽海岛是指以下的35个海岛:! m0 y/ k, c' U! V; k' Y; B
觉华岛、长山群岛、菩提岛、长岛、刘公岛、灵山岛、秦山岛、连岛、崇明岛、嵊泗列岛、岱山岛、东极岛、普陀山、大陈岛、玉环岛、洞头岛、南麂岛、嵛山岛、三都岛、平潭岛、湄洲岛、东山岛、钓鱼岛、南澳岛、万山群岛、川山群岛、海陵岛、南三岛、东海岛、涠洲岛、分界洲岛、蜈支洲岛、永兴岛、黄岩岛、永暑礁。
' y* q i* z$ g: W9 q8 G9 F5 M更多滨海旅游预报 尽在中国海洋预报
7 n, t/ W( O: c, e4 c. c2 p' k, B0 ]3 w" f
. W1 a# s; [. W& P8 y4 x9 O# h$ e
PC端可登录中国海洋预报网http://www.oceanguide.org.cn
$ O3 ?# n: L) i" k
3 ]% B/ U, q' T H! I
! s9 r) V6 ?* ~# J L- ~移动端可使用中国海洋预报微信小程序2 b4 O3 a$ I; j& K# \( f
进入“中国海洋预报”微信小程序3 O3 G8 j2 h0 V4 H9 _, p& w! _% L
进入“全球海啸预警”微信小程序 |
