《海洋预报》| P-RSHMU蒸发波导预测与湍流通量相关性分析
' p. c9 [7 m' A. z% N3 x  P0 q
' D! }/ s" x0 E' _" P
. C9 d7 k$ _. N) h6 i9 s& B, JP-RSHMU蒸发波导预测与湍流通量相关性分析7 Q. b/ A7 T$ ~: {2 B( ]
( v9 ]/ B0 D* ?/ s# `% e
全文请用PC端下载 地址:  ?' y! u: J) {+ G2 E3 v9 \! J
: B9 D/ P) R' u* Chttp://www.hyyb.org.cn/Magazine/Show.aspx?ID=3511+ P6 _# M* w" d  j7 j9 t. j
读书小笔记
5 U- p( w% p- ?; s+ D作者:张利军 张超 王红光 郭相明 韩杰 张守宝, {! T3 I% `$ y7 X) C, {
单位:中国电波传播研究所, 山东 青岛 2661075 w+ Z0 |& S- N% U/ L7 i0 K" ~
分类号:P731.26
# P7 n% M; m# l, J% N' Q出版年·卷·期(页码):2023·40·第五期(66-72)
7 @5 |" L% s* Q  y4 n5 x3 i摘要:为更好地揭示蒸发波导形成机理与近海面湍流通量的定量相关关系,基于海上平台实测水文气象数据,引入稳定条件以及不稳定条件下预测性能较好的P-RSHMU蒸发波导模型,定量给出该模型预测蒸发波导高度与近海面湍流通量的相关分析。结果表明:P-RSHMU模型预测有效抑制了稳定条件下蒸发波导高度为40 m的情形;针对所有数据(不区分稳定条件),该模型计算的蒸发波导高度与潜热通量相关系数为0.92,与动量通量相关系数为-0.41,与感热通量的相关系数为-0.12;区分稳定条件,得到3种情形下蒸发波导高度与潜热通量均呈现显著相关,相关系数均大于0.9。这些结果为丰富蒸发波导的形成机理以及内涵提供进一步的数据支撑。
7 q% \# Q  b% y关键词:P-RSHMU模型 潜热通量 动量通量 感热通量 相关系数
0 o( K0 `! ^4 W, nAbstract:In order to better reveal the quantitative correlation between the formation mechanism of evaporation duct and turbulent flux near the sea surface, the P-RSHMU evaporation duct model is introduced because of its good prediction performance under stable and unstable conditions.The correlation analysis between the height of evaporation duct predicted by P-RSHMU model and turbulent flux is quantitatively given based on the measured hydro-meteorological data collected by the offshore platforms.The results show that: the P-RSHMU model can effectively suppress the evaporation duct height of 40m under stable conditions. For all data (regardless of stability conditions), the correlation coefficient between evaporation duct height and latent heat flux calculated by this model is 0.92, the correlation coefficient with momentum flux is -0.41, and the correlation coefficient with sensible heat flux is -0.12. In the three cases, the height of evaporation duct is significantly correlated with the latent heat flux, and the correlation coefficient is greater than 0.9. These results provide further data support for enriching the formation mechanism and connotation of evaporation duct.
, J6 j; l4 \7 b3 c) ^& Y4 eKey words:P-RSHMU model; latent heat flux; sensible heat flux; momentum flux; correlation coefficient
8 E2 i- X( j  P% u& h
8 y/ X5 v" U7 }. h% S' }
" @1 R# m/ Z1 ~6 v" X% _$ Q% ^
. B) Y2 \4 e& O7 l5 [0 ?  w读者也可以通过公众号菜单栏
% q% c4 V! K5 j7 l“相关知识”板块进入《当期目录》和《过刊浏览》" O+ P3 f" M+ _8 S% P# o
查阅详细期刊内容
* K; }# y3 l( t8 }未来两天海洋环境预报
5 Y- l: v5 G% I/ {( Q  H' b预计明天,. n% U3 a+ @$ n; W5 ~$ i
渤海有0.9到1.2米的轻浪;
4 t' m  r8 Z8 |. P6 c5 M) m6 n黄海北部有1.4到2.3米的中浪区;
3 ~# x+ s, o, `: m& d黄海南部有1.8到2.6米的中浪到大浪区;% U5 ?. a5 c; k+ o, A7 y
东海、钓鱼岛附近海域有1.7到2.5米的中浪到大浪区;  t: ]/ G+ J$ s# d4 b' \. e9 l
台湾海峡有1.8到2.2米的中浪区;
5 ?6 }# _2 I, i9 @台湾以东洋面有2.4到2.9米的中浪到大浪区;
- d% o* V. i+ Q  L; O( I( R+ Z巴士海峡有2.9到3.3米的大浪区;/ r! f5 Y( [; V5 F! A
南海北部有2.5到3.4米的大浪区;
# \% T! i1 g9 V, W1 i! ^0 h南海中部有2.1到3米的中浪到大浪区;
! k/ w5 z6 U- w, A+ J南海南部有2到2.6米的中浪到大浪区;
! q. b- O* R9 _9 s. P. E' B北部湾有1.1到1.8米的轻浪到中浪。
/ H4 m% T0 u* E预计后天,
$ e) S* G! G9 N5 A4 `渤海将生成新的大浪区,浪高1.3到2.5米;
0 _8 b9 F! W8 |4 h* W2 g  [黄海南部的大浪区维持,浪高1.8到2.6米;- ?5 h4 ~! t% R; R7 ]
东海、钓鱼岛附近海域的大浪区减弱消失;
( |; Y" E* g5 P" {! k6 X, H% [巴士海峡的大浪区维持,浪高2.4到2.9米;
2 P+ ?$ A9 Q0 @; _* J+ c7 e- e南海北部的大浪区维持,浪高2.3到3.1米;0 s1 m, `/ J& S) v0 X8 Z8 n
南海中部、南部的大浪区维持,浪高1.9到2.7米。
& u8 p4 ^' \# C* {
. e; u' G' D, A6 s! C; {2 A
" N* p1 _8 r+ B- }7 z$ L
/ c/ Z' `7 F# z* p5 a; u* ]
12月6~10日西北太平洋海浪数值预报
* t# A+ h; f  k/ @0 i2 N" Y美丽海岛海域海况! I3 O. ?4 p6 u% j6 I2 Y
预计明天,
0 ^, E. W( W+ f  p; b: E" [钓鱼岛、黄岩岛、永暑礁附近海域有2.1米的中浪,以上海岛不适宜乘船出行;
+ e) e) Z. C/ y) h! |; N永兴岛附近海域有2米的中浪,灵山岛、平潭岛、湄洲岛、东山岛、川山群岛、分界洲岛、蜈支洲岛附近海域有1.3~1.6米的中浪,这些海岛较适宜乘船出行和海岛游玩;
, a* V7 b. ~- p我国其他美丽海岛附近海域都是轻浪,海况不错,非常适宜乘船出行和海岛游玩。
4 s, ~: f: h" Y) E- y5 {" s9 \- ]' Q: q4 o
美丽海岛是指以下的35个海岛:
/ E2 e2 C' U0 U% A觉华岛、长山群岛、菩提岛、长岛、刘公岛、灵山岛、秦山岛、连岛、崇明岛、嵊泗列岛、岱山岛、东极岛、普陀山、大陈岛、玉环岛、洞头岛、南麂岛、嵛山岛、三都岛、平潭岛、湄洲岛、东山岛、钓鱼岛、南澳岛、万山群岛、川山群岛、海陵岛、南三岛、东海岛、涠洲岛、分界洲岛、蜈支洲岛、永兴岛、黄岩岛、永暑礁。
+ }* i9 s9 K! `% L: g; p  ?2 h' S更多滨海旅游预报 尽在中国海洋预报
6 V# Q( T" |& Z. X
- B1 Z8 [8 h3 P8 S. j
  p- _  u  R. j2 U+ |  U) t
; Q/ a* A, S, H4 k; PPC端可登录中国海洋预报网http://www.oceanguide.org.cn
9 {0 Q6 z8 l" Q8 l: t0 v4 {' e
8 _6 e# m7 s2 j3 K% s* @" N+ G  q5 x
5 H$ A5 G/ v% f& }
& D& T; c8 ]& K: N移动端可使用中国海洋预报微信小程序) D. p" s9 N; R% R" e+ I
进入“中国海洋预报”微信小程序
! c6 k- Y! r: r1 W- S进入“全球海啸预警”微信小程序
di86qae5r2
活跃在2021-7-25
