2 M; c" s5 f, ]( h, R" C: \
1 x$ @1 J z# ]) F$ l
1971—2020年南海生成热带气旋的活动规律与大风分布特征
9 e6 \2 b% {6 S9 r$ J全文请用PC端下载 地址:
0 P1 K+ ~9 H2 H/ E$ K4 {3 {, E! K
http://www.hyyb.org.cn/Magazine/Show.aspx?ID=3541) q$ p7 G/ X# d9 `' F
读书小笔记( {) x: C( A- a; }
作者:杨亚新$ b. D( \2 ~, C2 M
单位:江苏航运职业技术学院 航海技术学院, 江苏 南通 226010
# ]7 x# C, f$ a/ }7 Y分类号:P444. }& a& U1 M, \5 j) z
出版年·卷·期(页码):2024·41·第一期(104-111)% L. u m$ y1 _% I; V; \
摘要:利用东京台风中心提供的1971—2020年的西北太平洋热带气旋资料,对南海生成热带气旋的发生频数、发生源地、强度和持续时间、移动路径以及大风分布特征进行统计分析。结果表明:南海热带气旋主要生成于5—12月,其中6—9月为盛行期,约有70%的热带气旋生成;热带气旋生成位置季节变化明显,6—9月多生成于南海北部17°N附近,11月—次年4月多生成于14°N以南的南海南部,5月和10月为季节转换期,生成位置大幅北进或南撤;热带气旋中心最低气压为940~1 004 hPa,平均值为985.4 hPa,近中心最大风速为35~85 kt,平均值为48.3 kt,平均持续天数为6.2 d;热带气旋移动路径以西移和西北移路径居多,各月都有发生,其次为东北移路径,主要发生在5—6月;近90%的南海热带气旋10级以上大风以中心呈对称分布,大风圈平均半径为53.2 n mile,在7级以上大风中以中心呈对称分布的略多于不对称分布的,7级大风圈的平均半径为142.3 n mile。( r1 P, }# T8 U( i: s% @+ }
关键词:南海 热带气旋 活动规律 大风分布特征% \# ^- o# E" h9 d
# N3 y. [2 e7 I# Q. q! Z. u% EAbstract:Based on the data of tropical cyclones in the Northwestern Pacific from 1971 to 2020 provided by the Tokyo typhoon center, the occurrence frequency, origin location, intensity and duration, moving path and gale distribution characteristics of tropical cyclones generated in the South China Sea are statistically analyzed. The following main conclusions are obtained: tropical cyclones in the South China Sea mainly occur during May and December, in which June to September is the prevailing period, and the occurrence frequency in these four months accounts for about 70% of annual number. The seasonal variation of the cyclone origins is large. From June to September, cyclones originate near 17°N in the northern South China Sea on average. From November to April of the next year, cyclones originate in the southern South China Sea (south of 14°N). May and October are the seasonal transition periods, and the origin locations of cyclones shift northward or southward significantly; The minimum pressure of the cyclone center is 940~1 004 hPa with an average of 985.4 hPa, the maximum wind speed near the cyclone center is 35~85 kt with an average of 48.3 kt, and the average duration is 6.2 d; Most of the cyclones move westward and northwestward during June and December, followed by northeastward during May and June. Strong winds above force 10 associated with nearly 90% of the South China Sea tropical cyclones are symmetrically distributed with respect to the center, and the average radius of the strong wind circle is 53.2 n miles. The symmetrically distributed strong winds above force 7 are slight more than the asymmetrically distributed strong winds above force 7, and the average radius of the strong wind circle is 142.3 n miles.
, p- c u. C5 S& O5 i r6 K/ ^: [8 {Key words:South China Sea; tropical cyclone; activity law; gale distribution characteristics3 E% O- i- o4 ^' a \
! D: M8 p3 L6 i6 J' p/ o) [9 q' ^+ m9 J
读者也可以通过公众号菜单栏5 J M" R$ C2 w1 Z9 ]
“相关知识”板块进入《当期目录》和《过刊浏览》- E. v5 u- f1 W g: n
查阅详细期刊内容7 q2 J3 x3 j' ~* p% ^/ [. p$ ^
未来两天海洋环境预报2 n, G% E% L$ z. L0 c
预计明天,. D( g- Q& s6 u7 A$ I4 \
渤海、黄海北部有0.7到1.4米的轻浪到中浪;
" ]: M8 N: n) J, ~( _6 x' O# _黄海南部、东海、钓鱼岛附近海域、台湾海峡、台湾以东洋面有1.3到1.8米的中浪;) M/ \( M$ \5 Y% F& @/ ~
巴士海峡有1到1.6米的轻浪到中浪;
: y4 \7 f( T4 y* l南海北部、北部湾有1.4到2.2米的中浪区;
; n% N0 Y3 i" i3 M' e( b南海中部、南海南部有0.8到1.5米的轻浪到中浪。1 q% S$ q: _ N' F
预计后天,
; }- Y# P& h0 ?4 {6 D+ |东海、台湾以东洋面将生成大浪区,浪高2到2.8米。% a/ C( ^% G: h, F2 I
4月24~28日西北太平洋海浪数值预报
1 u. _/ g/ h7 G/ N% t美丽海岛海域海况
& \* J. V0 O3 G; p预计明天,
& t) V2 f2 j. r' E2 w东极岛、平潭岛、东山岛、钓鱼岛、川山群岛、海陵岛、涠洲岛、分界洲岛、蜈支洲岛、永兴岛附近海域有1.3~1.7米的中浪,较适宜乘船出行;2 }# j& K1 D' M. @ k" B* r
我国其他美丽海岛附近海域都是轻浪,海况不错,非常适宜乘船出行和海岛游玩。
, d* w: ^' A% Z7 {( M: _! [4 e% n美丽海岛是指以下的35个海岛:
+ J4 W5 L% M0 ~% I* ^9 C觉华岛、长山群岛、菩提岛、长岛、刘公岛、灵山岛、秦山岛、连岛、崇明岛、嵊泗列岛、岱山岛、东极岛、普陀山、大陈岛、玉环岛、洞头岛、南麂岛、嵛山岛、三都岛、平潭岛、湄洲岛、东山岛、钓鱼岛、南澳岛、万山群岛、川山群岛、海陵岛、南三岛、东海岛、涠洲岛、分界洲岛、蜈支洲岛、永兴岛、黄岩岛、永暑礁。* q% W. l5 p) C2 N
更多滨海旅游预报 尽在中国海洋预报
2 H3 F: v6 @ M: e4 |2 I# i8 y9 p5 v. }4 U1 E% e
) u0 {5 \! ~+ v# e! h) `PC端可登录中国海洋预报网http://www.oceanguide.org.cn y9 b6 q) n2 z: i
9 e) u3 e; `& u5 i
5 X; {, d$ |. P5 r移动端可使用中国海洋预报微信小程序+ X/ y8 v" r1 l1 u6 m
进入“中国海洋预报”微信小程序
4 ?& W- j' p/ ^! a' f1 \进入“全球海啸预警”微信小程序
~! ?7 |& {" f6 d |
