德国HYDRO-BIOS公司——LIMNOS水样采集器 : B+ t1 U- Q% Z+ A, m
LIMNOS Water Sampler
. k, R* T/ [4 D- y& k$ p+ n @+ `: o ?9 g/ S3 q
+ d/ `$ w+ e' P$ q
LIMNOS水样采集器(玻璃采水器)是一款操作简单的水样采集器,采水器的取水深度30米。采水器LIMNOS水样采集器由PVC固定器和可更换的1000ml玻璃采样瓶组成。为了防止样品被表面水污染,将处在关闭状态的采水器LIMNOS水样采集器系在一根线缆上,沉入水中。当采水器达到预期深度时,使锤将会撞击铁砧,这时硅树脂管将会弹起,允许水样进入采水器的样品瓶,同时将空气排出。0 g( R6 j+ L' d' }$ v" S- G$ Z
; X/ J$ _$ L$ o$ l/ {
1 M# U) H# E/ @: c1 W0 gLIMNOS水样采集器(玻璃采水器)订购信息:
: z4 h% y+ h4 K5 z436 140 采水器LIMNOS水样采集器3 i6 [' g' O5 V& h% _" k8 R: W% ]
采水器适用于30米水深,每套采水器带2个1000ml玻璃采样瓶和一个塑料包被的使锤
- k& t M9 v, h 长288mm,宽65mm,高350,净重6.5kg6 u5 n* c4 \, S( w
; Q: w9 J; r U; @5 j# i* c, c3 K
436 145 采水器的玻璃采样瓶
2 x/ X3 `0 L2 e8 X, T& _, B, `, N 采水器的采样瓶容积1000ml,适用水深30米,每个包装10只
" ~8 _2 G4 S" x' V- ?& X9 p 5 }- x H. g9 D. I/ `
440 002 采水器上塑料包被的使锤$ q. G; F2 ^2 L9 C+ z
孔径6mm,质量500g% A$ H9 E& p- c. t/ q) G. V
5 F7 t" y9 H3 b+ i
" a: h. h. K* z$ M% z7 Z代表文献:
9 W4 Q1 G3 r% G7 ^! u% G1.M. Raateoja1, J. Seppälä1, H. Kuosa2,2004.Bio-optical modelling of primary production in the SW Finnish coastal zone, Baltic Sea: fast repetition rate fluorometry in Case 2 waters.Marine Ecology Progress Series.267:9-26.! C. W0 t7 A9 R7 c* _
2.Rossberg, Marcelo; Wickham, Stephen A.,2008.Ciliate vertical distribution and diel vertical migration in a eutrophic lake.Fundamental and Applied Limnology / Archiv für Hydrobiologie.171:1-14. N8 L2 H& G% p& I! G4 c5 H
3.Hans Ulrik Riisgård, Coralie Barth-Jensen and Caroline V. Madsen,2010.High abundance of the jellyfish Aurelia aurita excludes the invasive ctenophore Mnemiopsis leidyi to establish in a shallow cove (Kertinge Nor, Denmark).Aquatic Invasions.5(4):doi: 10.3391/ai.2010.5.4.. Q4 e8 p4 _5 X8 {8 z1 S
4.David A. Strand, Arne Holst-Jensen, Hildegunn Viljugrein, Bente Edvardsen, Dag Klaveness, Japo Jussila, Trude Vrålstad,2011.Detection and quantification of the crayfish plague agent in natural waters: direct monitoring approach for aquatic environments.Diseases of Aquatic Organisms.95:9-17.
' |: B5 `/ E+ m" U) a6 B$ ?/ N5.Iria Durán, Oscar Nieto,2012.Water characterization in three industrialized harbours (Vigo, Bilbao and Pasajes) in North Coast of Spain.Marine Pollution Bulletin.64(2):410-415.! _- x2 ]- [. Y, p" J
6.Christopher O. Miles, Morten Sandvik, Sigrid Haande, Hezron Nonga, and Andreas Ballot,2013.LC-MS Analysis with Thiol Derivatization to Differentiate [Dhb7]- from [Mdha7]-Microcystins: Analysis of Cyanobacterial Blooms, Planktothrix Cultures and European Crayfish from Lake Steinsfjorden, Norway.Environ. Sci. Technol..47(9):4080–4087.
9 a ~, ~0 s8 o
, A% z% ^: f& o. ~
: J( M; k% g( z. L, I# e) Q ~( t更多关键字: LIMNOS水样采集器,采水器,水质采样器, 玻璃采水器,水体采样,德国HYDRO-BIOS公司,有机玻璃采水器
" y- F7 x3 S/ e* {& b4 g# G$ _( l5 ]+ r) {
<strong> |
