型号
0 H' P: A b* O( i | ACM2-RS4 q$ C$ c7 u: {" a) [
| ACM3-RS- H4 ~3 k& d2 d1 p4 }- E Y. @
参数
9 o `9 @; @3 b- E4 s | 水平二维流速 (X and Y)
9 r; e1 ~4 F4 P3 o8 | | 三维流速 (X, Y, and Z)
7 F; R; a2 ^+ c) U& s5 N |
量程 ~6 H& p7 W% q/ I
| 每个轴:± 250cm s-1
4 U; X* j. Z0 ]3 n) ~6 K# J | 每个轴:± 250cm s-1# B- D8 V1 I( ]* G. z8 K
精度
2 T, \& H1 `; |7 x | ± 0.5cm s-1 or ± 2% (0 to ±100cm s-1)
# B A* G/ I' N9 x% K( A | ) N+ J/ ~! b; P' @, w( v @
分辨率# H! K+ W1 T+ B8 v# W: P" v7 }, T
| 0.1cm s-15 E+ M r1 U$ y9 ]; t
$ D' ~/ ~" |- r+ h' O |
零点稳定性! k# k* I' _* R" G
| 小于 0.1cm s-1
6 h1 [, P! H) V* X; B | - {' }# Y5 i, C3 b3 f6 g
采样率0 Q4 _0 x+ B4 k
| 15 to 70Hz(取决于传感器数量)+ m& h1 a5 e, g
| 15 to 60Hz(取决于传感器数量)
$ z' ~4 |0 m+ E& g7 {. p |
数字量输出
( R2 j, { {. Q- L: G5 G | RS-232C# |+ q4 f1 W+ K& U+ S5 U( Y6 ?- C
; ~' p5 A' L# F [ |
模拟量输出
4 X) G" E3 Y7 m; J. m& E D | -1V to +1V
# O( u3 ?( I; W9 S5 f/ _) B! h | ! ?2 W, E7 h. {- M6 E' i
电源
. w0 |5 d& T! j3 C9 o1 R0 g" i | 12V DC (from interface)
7 Q& `# d8 [$ A7 v; t |
# v6 A- |8 J% h& M( @2 w |
尺寸* M8 b4 P! E- T7 E/ L4 z
| Maximum diameter: 34mm, Total length: 420mm
+ i9 n* D0 }4 ~$ [) u | / C" q! o( N |# \% L
测量区域
k& Z. \ E& P2 \' c) ] | Φ6mm×19mm
- y; s; s4 L' t0 Q! k1 i. f; U | Φ20mm (spherical shape)# ?/ B& m. V$ C* x
探头耐压
: }, M; @4 b, D) i# r, { | 5 m/24 h/ |0 M! N3 |6 F v9 u
| : x; E# e7 Q: ^& a8 y% ~
电缆, ]" X, v }3 C3 V# r& u
| 10m (standard), Φ6mm polyurethane outer sheath, 6-core cable' Q/ l2 [; ]; _# S+ M0 N
| # H& ^6 T* W7 }0 _
