XZ-0125多参数水质分析仪(带打印机,电池)--吾爱海洋
, Y) @4 j" F) w( p# X   S1 G# [" j. {7 `7 I
" Q& I9 O' m+ v& B8 l! \( E
一、XZ-0125型水质多参数测定仪产品概述:# _0 Y1 q8 h: Z: _: X
; y+ P, d# |: Z4 Q" P  XZ-0125型水质多参数测定仪适用于大、中、小型水厂及工矿企业、游泳池疾控中心、生活或工业用水的浓度检测,以便控制水的浊度、色度、余氯、总氯、化合氯、二氧化氯、氨氮、镍、悬浮物、铜、磷酸盐、DPD余氯、溶解氧、亚硝酸盐、铬、铁、锰、色度、TDS、水温,PH、水硬度、COD达到规定的水质标准。# J# Q: p2 V2 i; N
  4 q' g9 O# c! ~& c- o
8 z. W; \" P! k9 Z( |3 k- \" k  ! F  _8 [+ m$ r4 K
  二、XZ-0125型水质多参数测定仪原理:* S  V! j# a9 f. i" H9 l& i% x
  ( E  |  \0 i3 ?8 q' k1 O/ K
  本仪表应用全中文微电脑比例式检测,光电子比色检测离子。消除了人为误差,因此测量分辨率大大提高。( ]5 h2 \. w$ P! o/ e' {0 J
8 }7 l+ i7 |( c7 O* Z
4 a) [4 N; M- ~& C
8 ~+ [+ U  e5 d1 A  三、XZ-0125型水质多参数测定仪技术参数:1 y/ M+ N1 J4 B1 ^) v# R( i
  / x, C* q: e0 B7 q! i  f
  余氯、化合氯:0-2.5mg/L,0.01mg/L
8 p& I# y1 k% w$ C! {5 W- [! l% h  总氯:0-10mg/L,0.01mg/L
. u2 L, e" G" M; t; M6 @  DPD余氯:0-2.5mg/L,0.01mg/L
8 ]2 o4 i0 |8 k" L! l* E$ m! s  DPD总氯:0-2.5mg/L,0.01mg/L
1 b9 s1 l# X- a- X0 K/ H, G  低浊度:0-20,0.01NTU& Y$ a8 O# x/ y5 t6 Z/ R& R
  高浊度:0-1000NTU,0.1NTU
* R! ?5 _6 S* z6 V  二氧化氯:0-2.0mg/L,0.01mg/L8 u6 S$ {; Y! X  t
  氨氮:0-10mg/L,0.01mg/L
* c/ t6 Z5 S8 S  悬浮物:0-100mg/L,0.01mg/L* o7 h/ B: T" S$ _9 Z' \- L) \1 W
  磷酸盐:0-1.0mg/L,0.01mg/L4 @2 k+ a) z/ E+ z1 ]
  铜:0-2.0mg/L,0.01mg/L
9 H( j2 T) ~6 s3 K. O& F  溶解氧:0-12mg/L,0.01mg/L
% @. K% o. m$ m$ Y+ i# W/ b2 W- x  磷酸盐:0-2.0mg/L,0.01mg/L+ D5 {* x% h: f) x
  亚硝酸盐:0-0.3mg/L,0.01mg/L( V5 _' j8 _& ~" C9 A
  铬:0-0.5mg/L,0.01mg/L
. ?. I% C5 [. R3 x. X  锰:0-0.5mg/L,0.01mg/L
, h0 g/ {+ W9 L  铁:0-0.8mg/L,0.01mg/L: ^& W( o& d3 l3 S
  镍:0-1.0mg/L,0.01mg/L
1 f8 E! l" ~0 O( G  色度:0-100PCU,0.01PCU  s5 c* ?7 Z- B9 V3 _7 a# G' A. l6 ^
  高色度:0-500PCU,0.01PCU7 h0 D9 G3 ?5 g: R  U5 Y- @
  TDS:0-1000mg/1.5%6 _; R; o+ j, R
  2 m+ d' i, Y7 P
  PH:0-14ph! |' |' L" ?9 Q9 ]' F2 V. g
  * ~/ h! \" K- t
  温度:0-100°
2 _& S: k6 X6 f# Y8 ^1 i
# Z" c5 y9 [5 |  COD(滴):0-300mg/L
0 O! P, T0 k, F. u  1 [: V, C! e6 {9 N
  水硬度(滴):0.01-0.04mmol/L& t2 O0 l4 N& V) Z2 W( }
  q% J8 \+ x( H' ~* D1 r  四、XZ-0125型水质多参数测定仪特点:! Q7 K  w8 `0 A
, Z9 Z. |3 u6 B
4 A. S! X1 w& }5 j5 s  C% C. ^  1.微电脑,轻触式键盘,全中文菜单,采用背光高亮度LCD显示数值,操作和标定过程全中文提示,使用方便。
/ Y4 M9 m' |$ Z& u3 |( l) [  2.可自动调零和5点自动校正,量程有自动和手动切换,并且有数据非线性处理及数据平滑功能。0 G8 ?5 [) e6 c8 P4 q* p  I' r/ y
  3.本仪器采用特制高强度长寿命光源,*的恒光源半导体发光器使其光源恒稳定,而且光源寿命长达20年,开机时无需预热,可直接使用。
1 x0 {! w, w4 w  4.本仪器还具有选择离子测量功能,其光源自动切换,适用于水中25项常见指标的快速定量测定。5 M+ f6 I" L  O: i9 S' I* |
  5.主机内可选配大功率电池,既可用于实验室也可用于野外现场定量测量,充电2小时可连续使用4小时,即充即用。
& |! x. {* ]$ e9 B; f2 {  6.采用矩形光学玻璃比色皿,表面平整光洁,克服了圆管比色皿管壁厚薄不均匀造成每次测量的误差,重复性好,测定时更。
$ f$ ^9 o8 h( A3 Y  7.本仪器融合多项自主设计成果,技术先进,符合国标GB/T5750-2006生活饮用水卫生标准。
/ z& v: D: \3 k! ]
  ?6 i0 \- Q% w& [+ C5 ^
9 V" G# T$ N6 t% q4 I( i- Y4 P/ H  化学法与电极法的区别:, j- ~9 _# e! H1 d7 `. t
  ! z) t( I8 `- z1 _" @1 f; Y2 e/ c
  电极法:
+ p) r2 N+ x; r; r) @4 u6 O  9 z1 Y  e6 m5 o
  1.电极法操作简单,不需要检测试剂,但使用一段时间后需要重新校准。
' t/ Y( P; V3 F6 u0 G  2.使用寿命短,约一年,有的离子电极在检测介质不同寿命更短。8 i- R, _8 x4 c( k4 g+ P  y
  3.对于各元素之间的抗干扰较差,检测数据误差较大% g7 i$ F6 H- q+ ~+ Q: @7 P
  4.电极维护比较麻烦,清洗困难,离散性大。! I0 f& E) Q( Y
  5.运输玻璃电极易损坏。% n5 i' ]  @4 q5 C. _( F& F
  3 m9 A# S; D) X* f# s0 l- x
 化学分析仪器
. S# {4 r5 F' [9 R, }1 t+ v
3 S& E2 d  w; F8 h. o9 {9 a! n" |1 v. N  1.化学分析法是国家实验室所使用的仲裁分析方法,准确度高。
) B/ z# k: |' e  2.对于各元素之间的干扰可以用化学试剂屏蔽,做到元素之间互不干扰,曲线可进行非线性回归,确保了检测的准确性。0 W0 X+ D  H* u6 r
  3.取样过程是深入样品中心和多点采集,更具有准确检测。
: h0 l; |( Q  p) v  4.应用领域广泛,局限性小,可建立标准曲线进行测定,仪器可进行曲线自我检测。& B! T' J# Y/ F( Y" P; H6 k
  5.购买和维护成本低,维护比较简单。1 v6 ?. X" f9 o
  6.化学法*的缺点就是需要检测试剂(显色剂)。
9 C4 c. H$ O; B
, }/ ?4 ^! j4 h        资料下载链接:立即下载
wqldbdwvbo
活跃在2021-7-26
