XZ-0125 多参数水质分析仪(不带打印,电池)--吾爱海洋
, m; s- @, C. p, `( {7 X: ~, v. N6 _+ @/ y! {- w
1 `+ R$ `5 S" {% e+ J$ @, U
' \. ]+ p+ n+ S$ Q6 \上海银泽仪器设备有限公司专业生产XZ-0125型多参数水质测定仪,欢迎广大新老客户,:  2 S. q9 h5 r. j6 N$ P
  / A) s1 `" J0 R4 ?2 n. n& ?
  一、XZ-0125型水质多参数测定仪产品概述:' g+ `' \0 [2 d* g  |7 S
  , Z: {/ C. g& u5 f( G
  XZ-0125型水质多参数测定仪适用于大、中、小型水厂及工矿企业、游泳池疾控中心、生活或工业用水的浓度检测,以便控制水的浊度、色度、余氯、总氯、化合氯、二氧化氯、氨氮、镍、悬浮物、铜、磷酸盐、DPD余氯、溶解氧、亚硝酸盐、铬、铁、锰、色度、TDS、水温,PH、水硬度、COD达到规定的水质标准。" O! V! T5 ^7 w! C
  : W# G+ f& M. B5 q
  ; x! J: ~% R3 {' n* v# o( ^
  5 G; k2 R% U/ h" F  G, w! E
  二、XZ-0125型水质多参数测定仪原理:
' b  r! J2 L) ^5 T) Q  7 n1 L$ M6 Z4 M) W  l0 ~
  本仪表应用全中文微电脑比例式检测,光电子比色检测离子。消除了人为误差,因此测量分辨率大大提高。& _! M) c, J% \
  2 j' W4 e& [/ ^% O6 M! n
  ! I' Q" o$ L: t& v
. M3 R. b4 I5 K2 S  三、XZ-0125型水质多参数测定仪技术参数:
3 [1 d# e8 d* h  H7 t; l8 ^7 I  8 r# v: \0 q# f* O2 N% n( p
  余氯、化合氯:0-2.5mg/L,0.01mg/L5 k6 U  S: ?/ v7 n4 S
  总氯:0-10mg/L,0.01mg/L
8 C' e: }0 A! T  DPD余氯:0-2.5mg/L,0.01mg/L
' W, j: @! p; L5 R. d$ g1 h  DPD总氯:0-2.5mg/L,0.01mg/L
7 K# ?  ?1 b$ @  p5 ~  低浊度:0-20,0.01NTU3 z' B7 g! G0 H8 m  q
  高浊度:0-1000NTU,0.1NTU  S. f, Y( T# k
  二氧化氯:0-2.0mg/L,0.01mg/L" j& J( h1 b8 x/ A4 G- I
  氨氮:0-10mg/L,0.01mg/L$ }! h. i4 ^% x- v7 a4 l$ u
  悬浮物:0-100mg/L,0.01mg/L6 K* v1 s& f2 ~6 A
  磷酸盐:0-1.0mg/L,0.01mg/L
& I, c, u$ ^/ q8 `  铜:0-2.0mg/L,0.01mg/L
1 P8 x. b4 c0 U8 r8 f, u# ]2 l  溶解氧:0-12mg/L,0.01mg/L
. E7 [3 E9 T1 k' A; S& J  磷酸盐:0-2.0mg/L,0.01mg/L
& Y8 V# y( Z" P  亚硝酸盐:0-0.3mg/L,0.01mg/L& a& h$ E# j* r) h
  铬:0-0.5mg/L,0.01mg/L2 b. A% L, t& l5 C& A, @
  锰:0-0.5mg/L,0.01mg/L
  m& n  f6 L5 G+ a. s' a. R  铁:0-0.8mg/L,0.01mg/L
! W. M  j3 o7 M- ?& J4 \; X* [) }2 F  镍:0-1.0mg/L,0.01mg/L* [6 m8 p% H) G" M# ~
  色度:0-100PCU,0.01PCU
8 |3 E+ S7 u; m/ v  ^  高色度:0-500PCU,0.01PCU6 \5 V" j. l3 Z
  TDS:0-1000mg/1.5%/ I* n7 |! ?7 p: V! \
  5 ?8 v, r3 f- i! _5 C! \5 b1 J' M
  PH:0-14ph: y4 f' a4 ]6 H
3 Q2 h) L- }/ s4 S  温度:0-100°: i! y4 J8 A* w  K+ o! x+ Q
. K2 H- |. i  e$ c% T( u# Q! g% N  COD(滴):0-300mg/L+ s( r7 B2 U, v9 H; B7 [6 a
  , [; G4 x2 B8 f4 Y( ~& a
  水硬度(滴):0.01-0.04mmol/L1 c% e8 Q, M! ?) o
% i. n5 [0 `. F8 B* \7 ^  A  四、XZ-0125型水质多参数测定仪特点:
' j, p  V' I! `% o3 Q
5 C  Z! p6 @5 i3 `  0 S+ H, `$ t5 Y+ L
  1.微电脑,轻触式键盘,全中文菜单,采用背光高亮度LCD显示数值,操作和标定过程全中文提示,使用方便。- i+ w" j5 U* D* g& F0 y
  2.可自动调零和5点自动校正,量程有自动和手动切换,并且有数据非线性处理及数据平滑功能。
2 x+ B: K$ P2 Q9 ~- q5 n  3.本仪器采用特制高强度长寿命光源,*的恒光源半导体发光器使其光源恒稳定,而且光源寿命长达20年,开机时无需预热,可直接使用。
- C) I  z/ G" L  4.本仪器还具有选择离子测量功能,其光源自动切换,适用于水中25项常见指标的快速定量测定。; o  f2 u. W3 m0 W
  5.主机内可选配大功率电池,既可用于实验室也可用于野外现场定量测量,充电2小时可连续使用4小时,即充即用。- y8 K" b0 }5 c! P0 n2 G- K' O
  6.采用矩形光学玻璃比色皿,表面平整光洁,克服了圆管比色皿管壁厚薄不均匀造成每次测量的误差,重复性好,测定时更。) F+ N! m6 a! p
  7.本仪器融合多项自主设计成果,技术先进,符合国标GB/T5750-2006生活饮用水卫生标准。
7 E  y% \: b+ o  w* ?  + P2 ^% n+ y7 E; \' o
0 t) [1 k( `! K4 l5 H# u  化学法与电极法的区别:
' ]0 X+ C; W2 V6 u) A% f' e  : o9 q) c. v& M3 Z  n
  电极法:3 @* w! W. g, Z% {
: u% d/ ]8 h& ]" l  1.电极法操作简单,不需要检测试剂,但使用一段时间后需要重新校准。) z. e9 x( K% i; Y4 {
  2.使用寿命短,约一年,有的离子电极在检测介质不同寿命更短。
, c1 @4 Z6 \' s! ]; }" Y; T: G8 n  3.对于各元素之间的抗干扰较差,检测数据误差较大
; V# P; y, [0 K# T( s  4.电极维护比较麻烦,清洗困难,离散性大。, [9 l6 l7 c" |$ m7 @1 r3 I& U& v
  5.运输玻璃电极易损坏。. m& x3 n3 l5 S
+ |) q) ?. n0 I 化学分析仪器
, b* _& E$ Y9 B8 s& m# v6 o4 p: }
  1.化学分析法是国家实验室所使用的仲裁分析方法,准确度高。' s0 ~* I! Z  p$ w
  2.对于各元素之间的干扰可以用化学试剂屏蔽,做到元素之间互不干扰,曲线可进行非线性回归,确保了检测的准确性。
2 ~" d! `  C( h1 \' L: K  3.取样过程是深入样品中心和多点采集,更具有准确检测。
7 ~' f- T3 Z# O' D' V" P2 o) N  4.应用领域广泛,局限性小,可建立标准曲线进行测定,仪器可进行曲线自我检测。
7 W+ B; |+ |* ]$ e/ b9 `  U) X  5.购买和维护成本低,维护比较简单。
) z) G6 H6 R2 ]. O  6.化学法*的缺点就是需要检测试剂(显色剂)。
% ^; N% h( P. s- [2 x0 u% j3 D
+ j' h& f4 v: `: L' D( d- O        资料下载链接:立即下载
wqldbdwvbo
活跃在2021-7-26
